14th April 2011, 01:33 PM
Changing GQ Gearbox
I am about to replace the gearbox and clutch in my GQ ute Any tips, hints or tricks would be appreciated.
Keith.
14th April 2011 01:33 PM
14th April 2011, 02:01 PM
14th April 2011, 02:03 PM
RIP - valued member and true gentleman of this forum that will be missed by many!
obtain a couple of long bolts with the same thread as the bell housing bolts, remove the heads, slot the ends for a screwdriver or grind a couple of flats for a shifter.
Install these prior to reinstalling the gearbox - you can use them to help align everything prior to bolting up. I just used some cheapies from the hardware shop that happened to have the right thread.
Consider replacing all the clutch related stuff that may need replacing while you have it apart, spigot bearing/bush, gearbox input shaft seal, throwout race, yoke and pivot, etc.
Looking at another thread here on a related topic, be sure to eat a hearty carnivorous breakfast, esp if several cans were consumed the night before :-)
14th April 2011, 02:05 PM
growlers71gq
Gday Kieth someone with the knowledge will get to you. My understanding is that they are bloody heavy and its been suggested to use an engine hoist to assist in removal and replacement.
did that with the mate's G60. removed the seats and doors, and the panel in the floor, and suspended to box on an engine crane. On my MQ slid it under on a trolley jack. It had the remote transfer case, so that bit was easier :-)
14th April 2011, 02:11 PM
Legendary
yeah the Gearbox I found is a bitch to get back in. aftter i undone all the bolts for the gearbox it just about fell onto the ground ! But when i went to put it back in there is no room in the floorpan to move it around i ended up panel beating the floor pan arond the bell housing area to get mine back in wasnt much fun at all then on my second patrol when i done the clutch on that one someone else had already done it for me lol so must be a common problem ...........
14th April 2011, 06:33 PM
Removing the transfer case makes the job a bit easier, and lighter. Using the engine lift crane in through the front door is the safest way, you don't want that gearbox rolling off the jack.
Tony
14th April 2011, 07:05 PM
Smart like tractor
I agree with tony that gear box assembly weighs close to 200kg. if it falls off the jack or worse on someone there will be trouble
96 GQ coil/Cab
08 G6eT
14th April 2011, 09:52 PM
i take seats out and steering wheel off made a a frame that sits on the floor use a chain block off that, heaps easier daz
14th April 2011, 10:03 PM
daz44b
Now that's good thinking.
Tony
14th April 2011, 10:45 PM
Jeez you guys have never use a transmission jack have yas'? They raise high enough to let gear box down, they have a tilt pump, swiveling plate, and safety chains to secure box on top to stop it rolling off. Once let down as high as trolley jack. Hire one for job about $50 for day.
Tim
