20th April 2016, 09:33 PM
LED tail light wiring
In the process of re wiring my rear lights on my ute
Can something be done to stop the blinkers flashing so fast
Because of the leds?
Any help appreciated,cheers
20th April 2016 09:33 PM
20th April 2016, 10:03 PM
Dribble Master
I'm guessing the new ones are LED? You might need some load resistors
20th April 2016, 10:07 PM
Patrol Guru
20th April 2016, 10:10 PM
Dribble Master
Kimbo63
yep or that.............. couldn't think of what they were called hahahaha
The Following User Says Thank You to Clunk For This Useful Post:
Kimbo63 (20th April 2016)
20th April 2016, 10:39 PM
Seems expensive when you can buy load resistors for about $1.60 from some electronics suppliers.
The Following User Says Thank You to nissannewby For This Useful Post:
20th April 2016, 10:54 PM
Patrol Guru
nissannewby
You are spot on Matty just the first one I found on flea bay had the search on Aus only I think I got mine from China for around 5 bucks just and easy plug and play option
20th April 2016, 11:38 PM
Are the load resistors hard to install?
20th April 2016, 11:39 PM
#8
Flasher can seems a lot easier
21st April 2016, 01:32 PM
#9
you'll need 50 OHm load resistors cheap as chips but as you noted the relay is the easy option
21st April 2016, 05:02 PM
#10
I am he, fear me
Change the Flasher Relay... last ones I bought were under $5
Takes 10 seconds including opening the drivers door :-)
I certainly can't be rrsed splicing in load resistors... unless you need 1 off for the brake LED to fool the Cruise Control
Also means you don't get any issues with trailers etc
Make sure you get the correct pin out B-L-E and not E-L-B
http://www.ebay.com.au/itm/Car-Flash...oAAOSw5VFWJfkR
