Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: LED tail light wiring
    Apr 2016
    In the process of re wiring my rear lights on my ute
    Can something be done to stop the blinkers flashing so fast
    Because of the leds?
    Any help appreciated,cheers
    I'm guessing the new ones are LED? You might need some load resistors
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Or just swap your flasher relay for one of these
    http://www.ebay.com.au/itm/Electroni...4AAOSwcnpTmWAC
    98 GU ST wagon 6.5TD chev 5 speed manual dual batteries storage drawers big red air compressor 9L tank millweld front and rear bars millweld 4" snorkel 4" air box 3" tough dog suspension lift drop box and hybrid radius arms 12000Lb winch ARB front air locker Alpine MP3 player amp and a good set of speakers GME 2 way The list goes on
    yep or that.............. couldn't think of what they were called hahahaha
  6. The Following User Says Thank You to Clunk For This Useful Post:
    Kimbo63 (20th April 2016)
  7. #5
    North brissy
    Seems expensive when you can buy load resistors for about $1.60 from some electronics suppliers.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
  9. #6
    Dec 2015
    Perth WA
    5 Post(s)
    You are spot on Matty just the first one I found on flea bay had the search on Aus only I think I got mine from China for around 5 bucks just and easy plug and play option
  10. #7
    Apr 2016
    Are the load resistors hard to install?
  11. #8
    Apr 2016
    Flasher can seems a lot easier
  12. #9
    you'll need 50 OHm load resistors cheap as chips but as you noted the relay is the easy option
  13. #10
    W.A. (wandering aust)
    Change the Flasher Relay... last ones I bought were under $5
    Takes 10 seconds including opening the drivers door :-)
    I certainly can't be rrsed splicing in load resistors... unless you need 1 off for the brake LED to fool the Cruise Control
    Also means you don't get any issues with trailers etc
    Make sure you get the correct pin out B-L-E and not E-L-B
    http://www.ebay.com.au/itm/Car-Flash...oAAOSw5VFWJfkR
