19th April 2016, 03:49 PM
Work tow car advice
We are in the process of buying a tow car for work to tow vans interstate and the boss is pretty set in his ways about his Toyotas.
Now he has been looking mostly at the V8 Troopies at around the $29,000 to $35,000 mark with a 3500kg tow rating which is very important..
Most seem to be up north in QLD and elsewhere far away so getting a good look is not viable and will rely on the RACQ or the like to check them over.
Can anyone suggest other cars that would fit the needs we have... the reason we have said troopie is we will deck out the back so our driver can sleep in it and keep the caravans in mint condition.
Cheers.
19th April 2016 03:49 PM
19th April 2016, 04:01 PM
Hardcore
If say you'd be on the money but maybe check out a 2nd hand dmax or bt50. You could still put a canopy on and sleep in the back
Lucus30's 1999 GU ST TB45E
19th April 2016, 04:02 PM
200 series. Your boss needs to keep in mind it needs to be comfortable which the troopy,dual cab and utes arent. Easy enough to lay the seats forward in the back and sleep.
Even a y62 would be a good option.
19th April 2016, 04:12 PM
Patrol Freak
things like the ranger and other utes read the fine print on the 3.5T towing... not all is as it seems...
19th April 2016, 05:35 PM
Legendary
There ya go!
Ill drive for ya.
19th April 2016, 06:05 PM
Rocket55s fully worked 4.2 gu is up for sale...
Perfect towing vehicle imo. Everything already done just tow 'n go !!!!
The Following User Says Thank You to Hodge For This Useful Post:
19th April 2016, 07:05 PM
amarok would be worth a look
19th April 2016, 07:44 PM
I am he, fear me
Suggestion for other 'cars' towing between 3000 to 3500 other than the V8 Cruisers ?... IMHO none
If he is dinkium 'bout wanting it for towing and kitting something out for a sleep then (other than the crusier) it is a toss up between
An F truck et al
or
An Iveco/Isuzu/Mitsi etc light truck dual cab with the rear as a sleeper
We tow boats from 3 ton up to just under 6 ton all over WA and typical of a Gov't fleet have a wide variety of vehicles.
Ranger, Navara, Amarok, Patrol (ZD30), Prado, Dmax, Cruiser et al of the 'Car' size, IMHO, they all suck except the V8 cruisers.
Of the trucks the Isuzu is the most comfy and it just hums along
Bloodyaussie (19th April 2016)
19th April 2016, 08:06 PM
Cheers et i will have a look into iveco as i do think they are perfect for the job and am able to build a sleeping canopy on the back.
But still think the v8 troopy is the easiest way to go and will need very little modification to make into a sleeper.
Work utes are no way on the cards and do not suit our needs.
I might have to go to qld and pick a car up as this where they all seem to be.
Has anyone had pre purchase inspection done... how well do they go over a car?
19th April 2016, 08:13 PM
Just dont buy an ex mine vehicle.
The Following 2 Users Say Thank You to nissannewby For This Useful Post:
Bloodyaussie (19th April 2016), Stropp (21st April 2016)
