Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: How to use a HELI Coil tool to repair a stripped thread.
    Hi all not sure if any of you are familiar with these thread repair tools.
    Basically what Ill show is how to use it,,,, first I need to drill the thread out to a larger
    hole,, the drill is provided,, Then tap a hole to suit the new thread,,,,then screw in the new thread
    Ill do it bit by bit. These tools were very popular years ago with motor bikes
    stripping the spark plug hole.
    OK first is a view of the tool itself nothing to be scared of, its just
    a drill, tap and a tool to insert the thread and the threads themselves
    This is a permanent repair.
    Forgot to mention, what Im repairing is two stripped holes on my
    thermostat housing so I can return it to Mudski, the thread Ill repair
    is 8mm x 1.25 some call it 8mm fine
  2. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Irish (25th April 2016), MudRunnerTD (22nd April 2016)
    This shows only one hole has been drilled out to 8.3mm
    now to tap
    Hole is tapped to except the heli coil
    Once tapped its time to use the heli coil tool and screw the helicoil in position.
    You can adjust the depth but I didnt need to
    Sorry about the pics , all done now all you need do is break the tag off the heli coil
    so the thread is straight through
    Bolts are straight just pic makes it look a bit off.
    Now I can post it back to Mudski LOL
  8. The Following 4 Users Say Thank You to threedogs For This Useful Post:
    MudRunnerTD (22nd April 2016), mudski (22nd April 2016), Touses (22nd April 2016), Woof (22nd April 2016)
  9. #6
    Good write up....
    John I dont want the housing mate. I have no need for it.
  10. The Following User Says Thank You to mudski For This Useful Post:
    threedogs (22nd April 2016)
  11. #7
    Ok then it will become a "forum" spare if any one needs it down the road.
  12. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    growler2058 (23rd April 2016), Irish (25th April 2016)
  13. #8
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Handy DIY that 3D. Does the helicoil require a bit of thread locker, as a just in case, for vibration?
  14. #9
    80 Post(s)
    Good write up, TD. I recommend using anti seize on the bolt or stud that goes into the helicoil, because if they seize they will destroy the helicoil and make it very hard to repair.
  15. #10
    Quote Originally Posted by Touses View Post
    I suppose you could but there was no mention of it in the instructions
  16. The Following User Says Thank You to threedogs For This Useful Post:
