16th April 2016, 10:52 PM
desired performance mods for zd30 crd
Gday fellas,
Purchased my first 4x4 ute the other week (2007 zd30 crd)
Been reading about the nads mods to ensure
The motor does not go BOOM! Yes I understand
Most will say it's not needed for the crd but for my security
I proceeded and purchased what was needed to ensure it won't happen.
All yet to be installed hopefully be done before next weekend
Now, my question is performance wise what would be the best performance mods to get the best
Out of this thing.
The reason I'm asking is before I setup the egt gauge would it be sensible to upgrade exhaust and what
Would be the best to suit crd some say 3inch some say no
But all in all what's the best mods?
Yes sorry for asking a frequent question was just hoping if it could be all summed up under one post
16th April 2016 10:52 PM
16th April 2016, 11:58 PM
No the NADs is not needed for the CRD. The dawes will give you a smoother boost curve and the needle valve will allow you to control the spool up rate of the turbo. At all. But its needed if you want any performance gains. Thats for sure. Bigger pipe. Some say 2 3/4inch, some say 3inch. I personally think 3inch. Performance chip, egr blocked. Modified intake pipe, tricked maf housing to allow higher boost levels.
The Following 3 Users Say Thank You to mudski For This Useful Post:
BigRAWesty (17th April 2016), Rsayers (17th April 2016), TheCaller (5th July 2016)
17th April 2016, 01:15 AM
Thank you very much mate
Much appreciated
With the exhaust would there be a specific one you would recommend
17th April 2016, 08:24 AM
Ok there is heaps of info and mudski has pretty much covered most of it..
2.75" if you not doing nads so it retains some back pressure and doesn't throw codes..
But you doing the lot so 3"..
There are heaps of systems..
Personally I'm going a 3" cat less with a main muffler as its our main car..
Bigger maf housing and silicone intake pipe work will assist with the intake but in reality the stock air box is poor..
If your really chasing big number that'll be on the to do list but not critical for small gains..
Most recommend upping boost to 18-20 psi. They do really perform well.. and this is where your larger maf housing helps..
Upping the boost draws more air. The ecu doesn't like that.. so..
You need to either up the pipe diameter to slow the flow or you can get a maf voltage regulator..
Now there is a big debate about chips v's remap of late..
A chip is simple and some now you can select different modes.
A remap tune you can set to how you like it, and they can change things like maf values and even turn off the egr function..
So a remap tune can save you money on the mods really..
In reality every mod you do takes life off the car.. So personally I'm not going to far with mine..
But a bloke in QLD has spent $27,000 on the engine just to shut his td42 turbo mates up lol...
30 psi and nitrogen cooled intercooler..
The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
Nick-o-larse (9th April 2018), Rsayers (17th April 2016)
17th April 2016, 09:29 AM
SUCH IS LIFE
Keep it stock or just a 2.75 Beaudesert exhaust and enjoy years of performance
….................... On the move
________________________
______ 2017 D-Max _______
The Following User Says Thank You to Maxhead For This Useful Post:
17th April 2016, 09:51 AM
X 2 on the Beaudesert exhaust, a chip and NADS will give great results
You'll need to decide if a chip or re-map is what your after.
One member here was very happy with the results of the remap lol.
What will you be using the ute for???
17th April 2016, 10:25 AM
biggqwesty
What a fool he is. Lol
Not bagging the motor. But really? A person would throw more than what i put into my TD conversion just to shut his mates up.
Getting high boost isnt hard too. The ZD30 likes the high boost. Anything over 25psi using the OEM turbo is asking for trouble though. The turbine shaft is the weak, link in theses turbos and ive seen one and heard a few of these snap the shaft from running over 25psi boost.
I forgot about the remapping you can do to the CRD's.
17th April 2016, 10:54 AM
biggqwesty
Thank you very much mate for the advice and info
Same goes to whom have replied 👍🏻
Top bunch of blokes
17th April 2016, 10:59 AM
What will you be using the ute for???[/QUOTE]
It's main purpose is pretty much a work ute, I'm a bricky so
Carting my own tools and supplies, intend to go camping and use it
As a 4x4. My old mans got a 70 series land cruiser in better condition then mine
So travel a bit with him as he is retired now.
The Following User Says Thank You to Rsayers For This Useful Post:
threedogs (17th April 2016)
17th April 2016, 01:18 PM
I went with 3" exhaust. The CRDs manage the higher boost much better than the DI model.
2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
The Following 2 Users Say Thank You to Ronin For This Useful Post:
BigRAWesty (17th April 2016), Rsayers (30th April 2016)
