Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Work tow car advice
    Thomastown, Melbourne
    6 Post(s)
    Work tow car advice
    We are in the process of buying a tow car for work to tow vans interstate and the boss is pretty set in his ways about his Toyotas.
    Now he has been looking mostly at the V8 Troopies at around the $29,000 to $35,000 mark with a 3500kg tow rating which is very important..
    Most seem to be up north in QLD and elsewhere far away so getting a good look is not viable and will rely on the RACQ or the like to check them over.
    Can anyone suggest other cars that would fit the needs we have... the reason we have said troopie is we will deck out the back so our driver can sleep in it and keep the caravans in mint condition.
    Cheers.
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    If say you'd be on the money but maybe check out a 2nd hand dmax or bt50. You could still put a canopy on and sleep in the back
    Lucus30's 1999 GU ST TB45E
    200 series. Your boss needs to keep in mind it needs to be comfortable which the troopy,dual cab and utes arent. Easy enough to lay the seats forward in the back and sleep.
    Even a y62 would be a good option.
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    things like the ranger and other utes read the fine print on the 3.5T towing... not all is as it seems...
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    There ya go!
    Ill drive for ya.
    175 Post(s)
    Rocket55s fully worked 4.2 gu is up for sale...
    Perfect towing vehicle imo. Everything already done just tow 'n go !!!!
    Winnie (19th April 2016)
    Expert billyj's Avatar
    gordon
    amarok would be worth a look
  10. #8
    Suggestion for other 'cars' towing between 3000 to 3500 other than the V8 Cruisers ?... IMHO none
    If he is dinkium 'bout wanting it for towing and kitting something out for a sleep then (other than the crusier) it is a toss up between
    An F truck et al
    or
    An Iveco/Isuzu/Mitsi etc light truck dual cab with the rear as a sleeper
    We tow boats from 3 ton up to just under 6 ton all over WA and typical of a Gov't fleet have a wide variety of vehicles.
    Ranger, Navara, Amarok, Patrol (ZD30), Prado, Dmax, Cruiser et al of the 'Car' size, IMHO, they all suck except the V8 cruisers.
    Of the trucks the Isuzu is the most comfy and it just hums along
  11. The Following User Says Thank You to the evil twin For This Useful Post:
    Bloodyaussie (19th April 2016)
  12. #9
    6 Post(s)
    Cheers et i will have a look into iveco as i do think they are perfect for the job and am able to build a sleeping canopy on the back.
    But still think the v8 troopy is the easiest way to go and will need very little modification to make into a sleeper.
    Work utes are no way on the cards and do not suit our needs.
    I might have to go to qld and pick a car up as this where they all seem to be.
    Has anyone had pre purchase inspection done... how well do they go over a car?
  13. #10
    Just dont buy an ex mine vehicle.
  14. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Bloodyaussie (19th April 2016), Stropp (21st April 2016)
