8th April 2016, 01:26 AM
wiring up egt help
So, close to putting n new engine, but few jobs to do before hand, i have a egt and boost gauge to put in (luckily the engines out as i cant get the exhaust off so have to weld whilst its in there), now i have the understanding of where and how to do the probe, quick question on this though, where do people run the probe line along in the engine, i was thinking along the firewall, and do people put a cable cover over it?
now in terms of wiring the damn thing, this is what i bought http://www.ebay.com.au/itm/PYRO-EGT-...sAAMXQVT9SsjN8
the instructions are terrible, to the point, on the probe i have blue wire and a white wire, on the gauge i dont have a blue wire yet the instructions state BLUE - CONNECT TO SENSOR BLUE, so there is problem 1. i have a set of 2 wire cluster, red and black, which i am assuming is power source and earth, then i have a cluster of 4 wires red, black, white and green.my guess here is,
Red for ignition
Black for battery negative (or another earth)
Green is for the blue
and white for the white
if anyone can shed some light on this with the vague info i have written, would appreciate muchly.
Steve
8th April 2016 01:26 AM
8th April 2016, 11:00 AM
I am he, fear me
One of the red/blacks may be for the instrument lighting.
Something is a tad odd about the colour codes for the Pyro
Green/White is usually for 1200 degrees K type thermocouple which makes sense as the gauge is a 1200 degree instrument (ideal for pre-turbo and OK for post Turbo)
Most people use a a J type thermocouple for post turbo which is 750 degrees but the colour code is usually White/Red
Blue/White is usually for an S or T type and not a colour code normally associated with J or K type.
But.......
There are a heap of different colour standards depending on country of origin of the thermocouples so maybe a question for the seller?
8th April 2016, 11:14 PM
Rule of thumb for thermocouple colour code:
The darker colour is positive unless it is red, then it is negative.
Connect up the probe, drop the probe in boiling water, an electric kettle won't shut off if the lid is open, it should read 100C.
Type K is the most common on thermometers & multimeters, it can be: green (+) & white(-), or Red(-) & yellow(+).
Graham
The Following User Says Thank You to GeeYou8 For This Useful Post:
the evil twin (9th April 2016)
9th April 2016, 11:49 AM
I am he, fear me
Yep, good rule of thumb for sure... the jap standard J type the Red is positive but no biggee
The boiling water idea might help on J type but is outside the range of K type.
A multimeter might help but the difference will only be about 2 or 3 mV so would need a good one.
11th April 2016, 05:02 PM
have tried contacting the seller, but no response.
all i could find was red to ignition
black to battery negative
blue (which i will assume is the green) to sensor
white to sensor
so will now think the red in the 2 cluster is batter positive (though i unsure why there would be two wires for power, being ignition and battery direct) and the black to the frame somewhere nearby for ground.
11th April 2016, 06:36 PM
I am he, fear me
lovejones
white to sensor
As prev posted... does the gauge have lighting?
If so there is a better than 50 chance that will be the other red
13th April 2016, 07:55 PM
yer sure does, i hooked it upto a battery with just red and black pair and light comes on. tried with the red and black in cluster of four and nothing happened, so guessing the 2 reds are power 1 black negative, one black earth, the other two connecting to the probe.
14th April 2016, 06:04 PM
14th April 2016, 06:47 PM
I am he, fear me
Uummmm... depends on a couple of things but usually works OK (in the ranges and accuracy we are interested in anyway).
Dont 'splice' into the Thermocouple wires.
Just try connecting from the terminals of the existing gauge to the K+ and K- of the digital gauge.
Use light gauge copper wire not thermocouple wire to go from the existing EGT gauge to the Digital one (pins 3 and 4).
14th April 2016, 07:19 PM
Thanks ET. When I said splice (bad terminology on my behalf) I really meant just piggy back it into the current thermocouple plug together with the thermocouple wires already existing . Rough drawing below. I already got some very low profile copper wiring ready to go.
