6th April 2016, 11:11 PM
Gday All
Gday guys im Ben, just recently bought a 2012 y61. Been really happy with the girl and amazed at how well she goes, i have been very pleasantly surprised by its 4x4 capabilities especially on sand and given its quite heavy weight. Before the GU I owned a few Wranglers and a GQ.
So far the only qualms I have is excessive oil from the breather which is pooling by the turbo (will be installing a catch can) and for some unexplained reason the VDC button wont switch off the stability control. so i get to go hunting to probably find a loose connection or just permanently disengage it by removing the fuse (if possible ???)
6th April 2016 11:11 PM
6th April 2016, 11:34 PM
G'day and welcome to the forum mate.
6th April 2016, 11:55 PM
7th April 2016, 12:45 AM
7th April 2016, 01:03 AM
7th April 2016, 09:27 AM
Hello Ben and welcome to the Forum, might want to also check for an oily IC, that will tell you its leaking.
You may want to remove it and clean the IC the same time you fit a catch can, PM mudski for a great deal
on a catch can, lol
Check your oil level keep it at just under and that may cure your oil problems
7th April 2016, 01:11 PM
Heya Ben. Welcome. See you've been a member for a bit. Good to see you bangin up some useful posts!
7th April 2016, 06:46 PM
Welcome to the forum mate.
10th April 2016, 08:57 AM
Hi Ben welcome to the forum mate
