Results 1 to 7 of 7
Thread: Steering Column Mount Gauge Pods
    Hi Guys,
    Bought my first ZD30 and am in the process of setting up for NADS, among many other things.
    Firtsly, I want to set up EGT and boost gauges.
    Im not a fan of the pillar pods, however I see that column mount pods can be had also.
    Click Here
    Does anyone have / use these and can tell me what the view is like and do they block much out on the dash?
    Thanks in advance....
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    I'd be interested in this feed back aswell..
    Not sure if they are a replacement peice or glue on bit..
    Aug 2011
    River Heads Q
    4 Post(s)
    I have a combined boost/EGT Autron gauge mounted in middle of column cover and it does not restrict view of speedo or tacho. Works very well for me.
    However the gauge does not have a dimmer for background lights so is too bright at night. Auto electrician can easily fix. This may be just a DX issue as the ST's have a dimmer control.
    Attached photo is taken on an angle but in driving position, all is good.
    At the end of the day, all you have is yourself and all you need is your friends (and in our case our Patrol)
    2006 GUI1 4.2TDi Coil Cab "almost" standard
  5. The Following User Says Thank You to Wizard52 For This Useful Post:
    BigRAWesty (7th April 2016)
  6. #4
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by Wizard52 View Post
    That's also a 60mm gauge ain't it?
    That setup was another option for me..
    How did you find the alloy holder? Worth the extra coin??
    Pretty sure Mudski has a twin pod there ,buy the $20 one does the same thing.
    I have a pillar pod but also and a triple pod on the dash easy as to wire using
    some 7 core trailer 4mm wire.
    I have my Ecu-Talk mounted there
    http://www.ebay.com.au/itm/Black-Dou...AAAOSwHnFVi1dr
    Loving this one
    http://www.ebay.com.au/itm/Diesel-0-...AAAOSwEK9XAMx5
  8. #6
    Ballarat, Vic
    174 Post(s)
    Wiz, the dimming solution is quite easy. Will cost you $50. Redarc gauges are Autron re-badged. What you need is the 'Enhanced lighting controller'.
    http://www.redarc.com.au/products/pr...gauges_ga-elc/ and http://www.redarc.com.au/images/uplo...ion_Manual.pdf
    I have a DX with no dimming function & it does the job. You can set the brightness/dim-ness - only issue I have with it is that for the dimming level which suits me at night, it makes the gauge a bit hard to see during the day if driving with lights on. This probably has to do with my dimming preference, having had cataract surgery in both eyes. I can still read the gauge on dimmed in daylight, but it's easier if I just flick the lights off momentarily. It's quite a small unit, easy to find a spot for. Has + & - switches inside to alter level of dimming. Set & forget (ie. once set no need to access further, so easily hidden away under the dash somewhere).
    A Nomadic Life (Blog)
  9. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    BigRAWesty (7th April 2016), Wizard52 (7th April 2016)
  10. #7
    Aug 2011
    River Heads Q
    4 Post(s)
    Quote Originally Posted by biggqwesty View Post
    Just under 60mm external. I've had it for 6 or 7 years so can't remember cost but more than happy with set up.
  11. The Following User Says Thank You to Wizard52 For This Useful Post:
