Results 1 to 10 of 10
Thread: mq every time I hit the key it blows fuse
    Mar 2016
    Does anyone have any idea where I should start to look for the problem
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Ah... which fuse for a start?
    What have you done since it was OK?
    Macca
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by matthew68 View Post
    In the fuse box see which one is blown then track it back from there
    could be earth related bare wire or any combination you want
    Mar 2016
    I hit a big patch of water on the road a week ago the car stopped running it would start and run for 10 seconds and cut out again i found a blown fuse replaced it and it ran fine.A week later it cut out again the same fuse blown again but now when I put new fuse in and turn key on it pops straight away the car will run with out fuse for 10 seconds and stop have no ignition light or blinkers have lights , radio and dash lights.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    which actual fuse is blowing
    whats it for..........
    is it engine fuse
    battery fuse
    a little bit of description could go a long way in helping you.......
    80 Post(s)
    One tried and true method of finding a fault is to replace the fuse with a test light so you can pull sections of the loom in that circuit apart until the test lamp stops working. that will give you a starting point anyway and is way cheaper than replacing fuses . Good luck.
  8. #7
    Mar 2016
    I dont know as there is'nt a fuse box cover to tell me what the fuse is for the fuse box is by the wright hand kick panel and is the second fuse from the back on a mq swb patrol
  9. #8
    I would be looking in the engine bay first, have a really good look
    at all your wires especially around the battery. Use a test light as suggested.
    Where are you Mat some one close maybe able to assist two minds better than one
  10. #9
    TRAFALGAR VIC
    35 Post(s)
    Have a look at the starter motor might have crap on or around wires
    she's water logged some place or its bare wires
  11. #10
    May 2017
    I know this is an old thread, but incase anyone has a similar issue.....
    My MK did this same thing.. started to blow the Engine fuse.
    Now what I found with mine was a fault in reverse switch on gearbox..
    Motor would run fine until selected reverse.
    I unplugged the wires.. no problem blowing fuse.
    I made a jumper wire and connected the reverse light wires together, bypassing the switch.. not blowing fuses..
    Connect switch again.. pop goes the fuse.
    Hope that may help someone else with a similar issue..
  12. The Following 2 Users Say Thank You to Chevrod For This Useful Post:
    GQtdauto (10th December 2017), mudnut (10th December 2017)
