Results 1 to 5 of 5
Thread: Scangauge II MAF
    Scangauge II MAF
    Does anyone know if there is an xguage code for the MAF of the scangauge II for the crd patrol? Cheers
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Hi mate..
    Jump over the into section and and introduce yourself.. something we ask new members to do..
    But here is a list of codes of the gu.
    Fault codes
    0087 Fuel Rail System (Pressure too low)
    0089 Air in fuel System
    0102 Mass Air Flow Sensor
    0103 Coolant temp sender
    0104 Vehicle speed sensor
    0203 Throttle pedal switch
    0208 Overheating Fault (Cooling Fan control)
    0234 Turbo Over boost
    0301 Engine ECU
    0402 Fuel temperature sensor
    0403 Throttle pedal position sensor
    0406* Intake air volume VNC system
    0407 Crankshaft position sensor
    0502* Battery voltage
    0504 Auto Trans communication line
    0505 No faults detected
    0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
    0701 Injection Pump – cam ring position sensor
    0702 Injection Pump – TDC pulse sensor
    0703 Injection Pump communication line
    0704 Injection Pump – spill valve
    0705 Injection Pump – Circuit malfunction, poor fuel quality, Pump Control Unit Failure
    0706 Injection Pump –spill valve
    0707 Injection Pump injection timing control
    0802 Engine ECU (Barometric Pressure Sensor)
    0804* Engine ECU
    0807 Stop lamp switch/circuit
    0901 Engine ECU (calculation malfunction)
    0902 Engine ECU relay (incorrect voltage from relay to ECU
    0903* Engine ECU (internal signal processing malfunction)
    0905 Turbo Pressure (Intake air pressure sensor)
    1003 EGR volume control valve
    1004 Injection Pump – fuel cut out system
    1401 NATS locked
    1402 NATS locked
    1403 NATS locked
    1404 NATS locked
    1405 NATS locked
    1406 NATS locked
    1407 NATS locked
    1408 NATS locked
    * These codes do not illuminate the Check Engine warning lamp.
    W.A. (wandering aust)
    Handy... but... he's after the program codes to load into the Scangauge to monitor the MAF input to the ECU.
    Dunno if this will help or not from Geek Alert forum...
    TXD 686AF10110 ;reads OBDII MAF
    RXF 044145100000 ;the number 4 in the 5th position gives you two decimal
    RXD 2810 ;specifies scangauge to read 2bytes (0 to 655.35)
    MTH 000100010000 ; math is simple, multiply by 1, divide by 1, no adder
  5. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (28th March 2016)
  6. #4
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Ow.. don't mind me.. lol.
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
    the evil twin (28th March 2016)
  8. #5
    Nuff said lol nice list Kallen,
    As suggested Troy if you can jump over to the intros and tell us abit about
    yourself and ride that would be great, just something the forum asks of us all
    Polite and all ,,,No harm done
    This is in the Y62 section to MODS
  9. The Following User Says Thank You to threedogs For This Useful Post:
