27th March 2016, 07:34 PM
Scangauge II MAF
Does anyone know if there is an xguage code for the MAF of the scangauge II for the crd patrol? Cheers
27th March 2016 07:34 PM
28th March 2016, 02:53 PM
Hi mate..
Jump over the into section and and introduce yourself.. something we ask new members to do..
But here is a list of codes of the gu.
Fault codes
0087 Fuel Rail System (Pressure too low)
0089 Air in fuel System
0102 Mass Air Flow Sensor
0103 Coolant temp sender
0104 Vehicle speed sensor
0203 Throttle pedal switch
0208 Overheating Fault (Cooling Fan control)
0234 Turbo Over boost
0301 Engine ECU
0402 Fuel temperature sensor
0403 Throttle pedal position sensor
0406* Intake air volume VNC system
0407 Crankshaft position sensor
0502* Battery voltage
0504 Auto Trans communication line
0505 No faults detected
0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
0701 Injection Pump – cam ring position sensor
0702 Injection Pump – TDC pulse sensor
0703 Injection Pump communication line
0704 Injection Pump – spill valve
0705 Injection Pump – Circuit malfunction, poor fuel quality, Pump Control Unit Failure
0706 Injection Pump –spill valve
0707 Injection Pump injection timing control
0802 Engine ECU (Barometric Pressure Sensor)
0804* Engine ECU
0807 Stop lamp switch/circuit
0901 Engine ECU (calculation malfunction)
0902 Engine ECU relay (incorrect voltage from relay to ECU
0903* Engine ECU (internal signal processing malfunction)
0905 Turbo Pressure (Intake air pressure sensor)
1003 EGR volume control valve
1004 Injection Pump – fuel cut out system
1401 NATS locked
1402 NATS locked
1403 NATS locked
1404 NATS locked
1405 NATS locked
1406 NATS locked
1407 NATS locked
1408 NATS locked
* These codes do not illuminate the Check Engine warning lamp.
28th March 2016, 03:15 PM
I am he, fear me
Handy... but... he's after the program codes to load into the Scangauge to monitor the MAF input to the ECU.
Dunno if this will help or not from Geek Alert forum...
TXD 686AF10110 ;reads OBDII MAF
RXF 044145100000 ;the number 4 in the 5th position gives you two decimal
RXD 2810 ;specifies scangauge to read 2bytes (0 to 655.35)
MTH 000100010000 ; math is simple, multiply by 1, divide by 1, no adder
BigRAWesty (28th March 2016)
28th March 2016, 04:39 PM
Ow.. don't mind me.. lol.
the evil twin (28th March 2016)
28th March 2016, 04:44 PM
Nuff said lol nice list Kallen,
As suggested Troy if you can jump over to the intros and tell us abit about
yourself and ride that would be great, just something the forum asks of us all
Polite and all ,,,No harm done
This is in the Y62 section to MODS
