Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Fuel starvation, '92 TD42.
    Sep 2015
    Hi jff45.
    Yes, when we removed the banjo bolt we expected the little mesh filter you referred to. When we couldn't immediately see or feel it, we cautiously went "fishing", eventually convinced there wasn't one there when we put a screwdriver down to the bottom of the well.
    Yossie
    Sep 2015
    Hi MudRunner,
    There's certainly a difference on occasion in how long she turns over before kicking to life. Half-a-second versus about 3 seconds. But more like if she's been sitting for 20 - 30 minutes.
    I checked the air filter today and its in good nick. Not one you'd look at and say it needed replacing.
    I fitted a Ryco fuel filter (as recommended by the lads at Repco) last week as a first go at solving this problem. I was reading a post on another forum today, saying that the fuel delivery capacity of the Ryco filter is significantly less than the Nissan-branded filter because of the different micron ratings. Do you have any knowledge or view on this?
    Yossie
  4. #13
    Sep 2015
    Hi Rossco.
    I am suspicious of the priming mechanism. Is it serviceable, or would I just replace it?
    Yossie
  5. #14
    Sep 2015
    Jeeez! Scared me on two fronts! Possible split fuel line and $2000 pump rebuild. I want my problem to be solved by an easily-replaceable $2 o-ring!
  6. #15
    192 Post(s)
    Quote Originally Posted by yossie View Post
    Hi Rossco.
    Yossie
    Good question! I've never pulled one apart or know how serviceable they are. . . Hopefully others will know. .
  7. The Following User Says Thank You to Rossco For This Useful Post:
    yossie (12th April 2016)
  8. #16
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Hi Rossco.
    Yossie
    Hi yossie
    Not a serviceable item but appears to be working ok if you can pump it up and it goes hard should be fine rare to see one on a trol fubar try pressurising the fuel line and check for leaks like mudrunner did but use compressed air or a small pump and block off one end might show up a leak as there is normally no pressure in there
    98 GU ST wagon 6.5TD chev 5 speed manual dual batteries storage drawers big red air compressor 9L tank millweld front and rear bars millweld 4" snorkel 4" air box 3" tough dog suspension lift drop box and hybrid radius arms 12000Lb winch ARB front air locker Alpine MP3 player amp and a good set of speakers GME 2 way The list goes on
  9. #17
    Ballarat, Vic
    174 Post(s)
    As you are able to access both ends of the fuel line - suggest you just replace it. I reckon there is a 99% chance it'll solve your problem & won't cost much.
    A Nomadic Life (Blog)
  10. #18
    330 Post(s)
    That is actually quite a task on a wagon. Most of the lines are steel. I woul take the end off the tank and the other end off the primer, block one end with a plug bolt and stick an air gun in the other end and pressurize the line then trace along with a hose in your ear along the fuel line looking for an air leak. If there is one it sounds like a small one. Mine used to take up to 15 seconds or more to start when it was at its worst, sometimes it would not start without popping the bonnet and priming again
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  12. #19
    Ballarat, Vic
    174 Post(s)
    Ah, right. I was just thinking rubber hose.
  13. #20
    Sep 2015
    An update on the fuel problem:
    I consulted a fuel injection expert who took it for a drive and agreed that the problem was probably fuel constriction, possibly a blockage; and/or gunge caught in the leaf valve part of the primer pump letting fuel bleed back (like Rossco suggested, above). He thought I should try compressed air blast back down the fuel line, and clean the filter head (as much as you can!). Both of which I did. And it certainly improved the situation. The occurrences of hesitation and "flat" acceleration decreased - but still did happen. And I still had the hiss of air from the filter head after priming (not that my old ears could ever hear it, but the young blokes told me it was there).
    So, still suspicious of the primer, yesterday I bought a $5 plastic in-line fuel filter and bypassed the primer/filter head altogether. SUCCESS!!! It's a totally different vehicle. Full-bodied, gutsy acceleration, no hesitation, no jerky flat spots. So having confirmed the cause, I'm now looking for a suitable replacement filter head - and I'm going non-Nissan and forget about the primer altogether.
  14. The Following 2 Users Say Thank You to yossie For This Useful Post:
    Bigcol (12th April 2016), Cuppa (12th April 2016)
