Results 1 to 5 of 5
Thread: 4 speed auto tranny fill point
    Mar 2016
    Canberra
    Hi,
    I have a 99 GU 4.5 TI auto and want to take the pan off and replace the atf. I realise I will only get about 4 - 5 litres out. However, I want to check with others, is the plug on the rear of the transmission on the vertical section the fill point. I'm pretty sure it is, just checking.
    Thanks.
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    As far as I know you fill via the dip stick hole.
    You will only get about half the fluid out as most of it will be in the torque converter.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    That's how it's done. Through the dip stick tube.
    I use this
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    Mar 2016
    Canberra
    OK thank you. Have a new filter, gasket and small o ring so will do it tomorrow.
  6. #5
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    Filter is a metal gauze and doesn't need to be replaced. Simply wash it with solvent
    John
