26th March 2016, 03:47 PM
4 speed auto tranny fill point
Hi,
I have a 99 GU 4.5 TI auto and want to take the pan off and replace the atf. I realise I will only get about 4 - 5 litres out. However, I want to check with others, is the plug on the rear of the transmission on the vertical section the fill point. I'm pretty sure it is, just checking.
Thanks.
26th March 2016 03:47 PM
26th March 2016, 04:37 PM
As far as I know you fill via the dip stick hole.
You will only get about half the fluid out as most of it will be in the torque converter.
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
26th March 2016, 06:46 PM
That's how it's done. Through the dip stick tube.
I use this
98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
"GO YOU CROWS"
27th March 2016, 01:19 AM
OK thank you. Have a new filter, gasket and small o ring so will do it tomorrow.
27th March 2016, 08:15 AM
Filter is a metal gauze and doesn't need to be replaced. Simply wash it with solvent
John
