19th March 2016, 07:41 PM
Gday mate, welcome to the forum, just a thought, if you can hear a solenoid, is it the solenoid for your dual battery setup?
I have my red arc solenoid wired via the blue wire on the unit to a momentary on button on my dash. This allows me to link the batteries to jump start off the auxiliary battery. When I push the button to link the batteries, there is an audible click from the solenoid.
Anyway, just a thought, following the wires would help you to find out for sure. As for the plugs, check out the website for the 12 volt shop in Western Australia,
http://www.12volt.com.au/redirect.ht...03/plugs2.html
Cheers.
93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
The Following User Says Thank You to Patrol'n For This Useful Post:
19th March 2016 07:41 PM
19th March 2016, 07:48 PM
I am he, fear me
X2 with escix and others... the push button will most likely be to manually parallel the two batteries.
Those sockets are a standard 32 volt "Flat Pin T" power socket.
You can get plugs to suit at any electrical and/or accessory supplier.
20th March 2016, 11:27 AM
escix
Do you have dual battery, it may be for emergency (override) starting switch for the isolator.
x2 for dual battery parallel solenoid, DC outlets reinforce it.
Graham
20th March 2016, 11:37 AM
Thanks guys. Thinking it might be to connect the aux battery for starting?
20th March 2016, 12:46 PM
Either a jumper for when you have a flat main/start battery or possibly a glow plug switch. It could be for the ejector seat they did come standard on some models. Get your wife to sit in the passenger seat and press it.
20th March 2016, 08:46 PM
Turn on the headlight and press the button and see whether you are noticing any difference in the brightness.
Depending on the battery status it can be high or low, but it is not a guaranteed method, but worth a try.
ando89
Make sure the roof is closed.
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
The Following User Says Thank You to MyGU8 For This Useful Post:
20th March 2016, 09:43 PM
#17
Moderator
Get someone to push it and you find the solenoid under the bonnet you can hear switching, then trace what it it switching, a solenoid is just a big Relay so it should be very easy to figure out. It could be absolutely Anything though? It it an On/Off switch or a Momentary On switch?
Everything is a guess without tracing wires. Whatever it is switching could have been removed by a previous owner years ago making it just some random switch.
Check out my Toy -->
Rogue Dung Beetle
20th March 2016, 11:14 PM
#18
Clunk
For the passenger ejector seat
Im going with this option. Could come in handy if its a zd30di lol.
21st March 2016, 08:07 PM
#19
LOL.... This is a thread that needs to be a sticky in the electrical section
The Following 2 Users Say Thank You to Yendor For This Useful Post:
Bloodyaussie (21st March 2016), MudRunnerTD (21st March 2016)
21st March 2016, 08:43 PM
#20
Thanks for the suggestions. Wife not keen to sit and push! Need to trace those wires I guess. Seems like a momentary pb as its position doesn't change.
