Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: GU LHF Power window intermittently not working
    Not sure if the cables rum through the same place on a GU as they do on a GQ, but have a look at the white/blue cable that runs through the bulkhead on the drivers side..... that's where mine had a break in it, but I had issues with all windows, not just one
    Advanced ando89's Avatar
    Mar 2016
    Perth, Western Australia
    YEEEEEE HAAAAAAAAA i sorted it. Pulled the switch out and swapped it with the on in the back door issue has moved to the back door. new switch is on order from Patrolapart of $85.59.
    Thanks every one for your help. This just shows that KISS (Keep It Simple Stupid) really works
  4. The Following User Says Thank You to ando89 For This Useful Post:
    Clunk (17th March 2016)
  5. #13
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by ando89 View Post
    .......I have already replaced the motor and assembly. Before i go and replace switches and rip out wiring shortly followed by burning the car does anyone have a schematic of the electrical system i can get a copy of or can tell me what it the most likely cause.
    Wow! Yes KISS!
    >>>tappin from tassie
    Hello from Under Down Under!
  6. #14
    Mar 2016
    Well on the bright side i have a new motor that won't give me any issues for a few years
