Results 11 to 20 of 24
Thread: New exhaust has surface rust?
    Advanced UVB76's Avatar
    Dec 2014
    Newcastle
    Appreciate all the input, guys
    The exhaust has a 3 yr warranty so if it rusts out it's covered, and I don't live near the beach so there's no chance for salt water to get in and speed up the process.
    How important is some silicone sealant on the gaskets, like RTV? And the heat shield on the factory exhaust is completely rooted, do I really need to replace it?
    Big Red '99 RD28
  2. The Following User Says Thank You to UVB76 For This Useful Post:
    BigRAWesty (17th March 2016)
    43 Post(s)
    Quote Originally Posted by UVB76 View Post
    Again silicone will just burn away..
    If it didn't come with gaskets then you'll either need to find some or make some..
    Dec 2014
    Newcastle
    Yeah, it came with gaskets but there's a note in the packaging that says to use high-temp silicone gasket stuff with the gaskets...
    Big Red '99 RD28
  6. #14
    it came with silver perforated 3 hole gasket
    pretty sure I dont have the heat shield on mine, they are a PITB at the best of times
    Any HT rtv should do the job for you. lol
  7. #15
    Advanced ando89's Avatar
    Mar 2016
    Perth, Western Australia
    If you are really worried about it i would put some heavy duty high temp anti seize on the bolts as threedogs suggested. Wire brush it and paint it with high temp paint. But remember it is an exhaust and the first time you go off read half the paint will be scratched off.
    If you really wanted a exhaust that wasn't going to rust you should have got a 316SS exhaust. Nothing wrong with mild steel 90% of exhaust around the world are made from mild steel.
  8. #16
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Sorry missed the bit about the heat shield before - yes replace it. It helps to stop your exhaust cooking all the other stuff in the engine bay. There is a thread here somwhere about batteries getting overheated.
  9. #17
    43 Post(s)
    Quote Originally Posted by 4bye4 View Post
    I'm personally going to wrap all my stuff when the time comes
    174 Post(s)
    I question the value of wrapping exhausts for everyday use when ceramic coating is more effective & isn't overly expensive, particularly on mild steel exhausts where one occasionally reads of 'wrap- induced rust'.
  11. #19
    Have to agree on wrapping a daily driver I think more benefits would come from ceramic coating it,
    A daily driver will condensate too much, a lot of negitives written about it.
    I had some block huggers had and made a huge improvement to under bonnet temps.
    Do some more reading if you really want to wrap the dump pipe. some with plenty of $$
    probably wouldnt give a shite and tell you to do it
  12. #20
    462 Post(s)
    I wrapped the dump pipe on my pipe. Did it to the old 3ltr too. Worked a treat, i could put my hand on the pipe while the motor is running so it works. As for rusting. No issues there. The heat of the pipe quickly dries. The dump pipe on my 3ltr was wrapped for 2 years and the pipe was like new under it when i removed it. You can buy a sealing spray to coat the wrap too if you want.
    My 2c.
    4bye4 (18th March 2016)
