Results 11 to 20 of 29
Thread: 12v power for the Kids in the back
    Yeah the standard 12v jack is a 2.1amp or a 1amp. That say the iPhone needs 1amp and the iPod needs 2.1amp. If you charge an iPhone on a 2.1amp charger it's like a fast charger. The iPad will maintain charge on the 2.1amp port if it is in use.
    I ran hema maps on my iPad for the Simpson trip. It maintained charge and recharged on the 2.1 but took most of the day to climb back up when I drained it.
    Each door got a 2.1 amp and1amp port so should handle the job. I was a little concerned with the load but Rodney was confident it would be fine. Happy days.
    Yeah my ipad does the same when plugged into my CD player. If in use and plugged in, in a full day will gain about 10% charge. I just make sure it is charged before I leave home and then it stays 100% the whole time.
    BigRAWesty (7th March 2016)
    461 Post(s)
    I have Samsung gear and they all like 3amp chargers. Which makes it hard to find these things.
  5. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (8th March 2016), MudRunnerTD (8th March 2016)
  6. #13
    I've never seen a bigger output one!! If you find one post a link I'd be keen as mate!!
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  8. #14
    Aug 2010
    adelaide
    OH LEATHER IS NICE
  9. The Following 2 Users Say Thank You to my third 256 For This Useful Post:
    MudRunnerTD (8th March 2016), Rirz (2nd April 2016)
  10. #15
    Quote Originally Posted by my third 256 View Post
    They are sneaky the way they advertise the current output.
    That is identical to what Darren has, 2.1A for one slot and 1.0A for the second slot.
    Combined you have 3.1A
  11. #16
    174 Post(s)
    Yes & there are plenty out there which claim to ouput 2.1A which don't! The one I fitted into my second glovebox for charging my Ipad3 doesn't even provide sufficient power to maintain it's charge status when being used, it only slows down the discharge rate. It will recharge if the ipad is not being used. And it wasn't a cheapie either.
  12. #17
    My Samsung phone charges ok through one of the double Baintech type USB outlets
  13. #18
    and the problem with that one is you don't know which one is assigned with 2.1amp and which is 1amp. and it will be assigned! Tricky bastards. Id love to find a double 2.1amp output each side. something with more would be great too.
  14. #19
    One of the better mods I've seen lately what made you think of that position ??
    http://www.ebay.com.au/itm/5-1A-High...3D291541586443
    How do they work out 5 amps is it all three combined??
  15. #20
    461 Post(s)
    Thats what my Baintech socket does. Quite disappointed. I now use a Genuine Samsung 3amp fast charge ciggie socket outlet one and is works really well.
