Results 1 to 10 of 11
Thread: Replacement exhaust CRD motor
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    For those who have done the exhaust upgrade on the CRD 2007 to 2015, can you please add your experience below.
    Type, cost (if you want to share) quality, performance and any issues.
    I am also wanting information on the dump pipe size and mating flange configuration.
    Some exhausts have a 2-14" dump pipe and others claim to have full 3" dump pipe.
    The 2012 model as I have been told has a very hard to get to turbo flange causing problems with dump pipe sizes over 2-14", I do not believe this and hope someone can clarify.........
    If over 2-14" they are prone to leak at the flange.
    Any help would be great.
    2012 GU8
    If you go the 3 inch dump make sure it is well engineered and fitted.
    Otherwise you will have issues with;
    Dump Pipe snapping at the flange (very irritating)
    or
    Sheared/pulled/stretched Turbo studs (very expensive and very irritating)
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    rusty00 (6th March 2016)
    175 Post(s)
    I had a 2 & 3/4 exhaust from Beaudesert on my CRD (2009).
    Cost: It was around $1000 from memory.
    Quality: Great!!! I've so far had 3 exhausts from there. Navara, Patrol 3.0, and Patrol 4.2. Every time, packaged well, everything lined up perfectly, always threw in extra gaskets and bolts and instructions were excellent.
    Fitting: dump pipe at turbo was atrocious to get to on the 3L. Many hours, beer and swear words were consumed during that saga ... Seized bolts etc...
    But the rest was a breeze.
    Performance: opened her up heaps, but needed Dawes/needle adjusted to accommodate for more boost.
  6. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Rock Trol (6th March 2016), rusty00 (6th March 2016)
  7. #4
    Seems the 2.75" is better for the CRD motors Beaudesert are the only sellers of that size I think
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #5
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    I have the 2 3/4 Beaudesert. Dropped the egts by between 50 to 100 deg. Was running 19psi before but had to drop back to 16psi with the next exhaust as it kept over boosting and going into limp mode.
    But never a problem since. I had it fitted for me to save all the swearing. Runs a lot better especially with the Dawes needle.
  10. The Following User Says Thank You to Patrol-Guy For This Useful Post:
  11. #6
    Jun 2015
    South Eastern VIC
    Hey PG, what year GU do you have
    2012 GU8
  12. #7
    Evn K07 had one fitted,
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #8
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Model: 2012 GU8 Patrol
    Dump size: 3"
    Exhaust: 3"
    extra info: High flow cat, High flow muffler
    company: Scott's Rods
    price: $945
    No problems with fitment, Did it myself, Had pyro bung welded in as well, All hangers lined up fine I just had to drop front swaybar off passenger side when installing. Made turbo spool nice and quick, and isn't too loud or droney on the highway. Would I buy it again? Yes.
    1998 GU RD28T: RIP
    1996 GQ RD28T: RIP 11 days later
    Hello 2012 GU CRDZD30
    Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
  15. The Following User Says Thank You to trekster For This Useful Post:
  16. #9
    Oct 2013
    Brisbane
    I have a stainless Outlaw4x4 exhaust. 2.5in dump into high flow cat and 2.75in back all mandrel bent. $1,050 installed by Right Price Exhausts at Moss St Springwood. Really happy with it and performed very well with Unichip Q4 dyno tune.
  17. The Following User Says Thank You to coiled For This Useful Post:
  18. #10
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    3 inch Pacemaker king Brown exhaust. High quality and fits nicely to the existing attachment points. Mounting points on exhaust look very solid.
    I needed a dawse valve after fitting as it tended to over boost.
    The motor also seems to cool down faster when I idle it before shutting down. I normally wait for the water temp on scangauge to drop to 85 and this doesn't take as long with the bigger exhaust.
  19. The Following User Says Thank You to Rock Trol For This Useful Post:
