6th March 2016, 11:43 AM
#11
Moderator
I reckon you want some Nissan factory steelers mate in 16x8 pos10. I figured it might have been stud length on the alloys.
Check out my Toy -->
Rogue Dung Beetle
6th March 2016 11:43 AM
6th March 2016, 12:00 PM
#12
The 747
MudRunnerTD
If I could find some then they would be fine.
6th March 2016, 12:12 PM
#13
so the 14mm studs would be from the 100s and the thread would be 14mm x 1.50
Noticed super cheap sell them as well
http://www.ebay.com.au/itm/Wheel-Lon...8AAOSw9mFWGzHs
6th March 2016, 01:15 PM
#14
I am he, fear me
MudRunnerTD
Note also that a Pos13 in a 16x8 will be something like a Zero in a 16x7
MudRunnerTD
Correction. It will be something like a Neg12 in a 16x7 assuming thou want the tyre to sit in the same place in relation to the outer guard?
Hi mate, i musta missed something... Pos 13 on a 16x8 and pos 13 on a 16x7 won't change
Offset is offset... so a 265 on an 8 inch rim will sit in the same place as if it is mounted on a 7 inch
You haven't changed the track and you haven't changed the tyre width
If going from say 265 to 285...
If there is an issue with side wall clearance you would only need to change offset x 1/2 the tyre width change
IE to keep the side wall in the same position relative to a guard and you increase the tyre width by 20mm then you only increase/decrease offset by 10mm
The other thing is that the other sidewall will change by a full 20mm tho
6th March 2016, 08:42 PM
#15
Moderator
the evil twin
Yes you are correct mate. Sorry i was mistaken. You should have seen me trying to draw that in the air this morning at the dining table.
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
BigRAWesty (8th March 2016), the evil twin (8th March 2016)
8th March 2016, 12:53 AM
#16
Winnie
He trailer has 14mm Toyota stud, Nissan's are 12mm so the special nuts for those rims will not fit.
I cannot get 12mm studs for the trailer and I cannot get 14mm nuts for the rims.
That is a good call, didn't think of that though. I think 16x7 with a 0 offset will be much easier to find.
So is it a stud issue or offset to fit a patrol rim?
If studs are a couple of new hubs in budget? You'll just need to know axle bearing size..
MudRunnerTD
I can imagine an "air paccaso"
8th March 2016, 06:26 AM
#17
I have a set of 3 rims but in 15inch.. cannot remember the offset right now but are suited to rodeo or hilux and was going to use them on my trailer but not sure if I still will..
Otherwise ask me what size you want and I can order them for you at very special mates rates... maybe a set of fully sick alloys.
8th March 2016, 06:53 AM
#18
The 747
Bloodyaussie
Sms coming to you now
