Select the "paper clip icon" then "Add files" then "Browse"
Search for where your files are located on the HDD.........hold down the CTRL or SHIFT key to select multiply images then select "Open" then Select "Upload" then select "Done" when they finish uploading
Then next to the paper clip there is a down arrow, select it and it should come up with a file name and just click on it.
Hope I got that right!
Thanks, Im guessing it must be a bit different on a Mac? I get the dialog box shown, but 'select files' does nothing, so I have to use 'Basic uploader' which results in a thumbnail duplicate, same as if I try to use 'File upload manager' via 'Manage attachments'. Same in both browsers I use (Safari & Firefox). Also even small pics get shown much larger in the final post like in this one. Generally I use a web hosting service (Fickr) which allows me to size pics, but if I just want to do a quick upload I always get a result like this post.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
