22nd March 2016, 08:13 PM
#21
I have the same problem on my 2010 Patrol. Interestingly it is on the passenger front, not the drivers which obviously have had much more use.
22nd March 2016 08:13 PM
10th April 2016, 08:51 AM
#22
I'll give this a go today, had the drivers side replaced as part of the deal when I bought but the passenger side is also sticking
16th May 2016, 06:30 PM
#23
Wish I had of seen this a couple of weeks ago, paid $160 for two from a wreckers and they are just as bad as my originals!!
2008 GU ST Bog stock and no smoking barrels!
The Following User Says Thank You to Beni C For This Useful Post:
rusty_nail (16th May 2016)
18th May 2016, 04:18 PM
#24
I am having the same issue, I might try the cleaning method before pumping any money into it.
18th May 2016, 06:29 PM
#25
Bitumen Burner
I was gunna post something about this too, but somebody beat me to it.
I changed my driver's seat belt only around 5 years ago and it's doing the same thing.
Will try the suggestions provided and get back to you with the result.
Take care out there.
Rossco
13th August 2016, 08:06 PM
#26
I have done it with metho and work well
14th August 2016, 01:47 PM
#27
BillsGU
Yep - seen that before as well. I have used many, many different seat belts in different cars over a lot of years and I never had to use "cleaning wire" or "cleaning tape" or any other shyte. The belts have always worked - except in Patrols.
The fact is the wind mechanism in the belt loses its tension reasonably quickly and just won't work. You would think that after years of this crap Nissan would have woken up to the fact some time ago and replaced the belts in later cars - but they didn't. When I installed the new belts I tried to pull the old ones apart as I thought they could be wound on a bit more. Good luck trying that! The after market ones work perfectly.
How long did it take to install the new ones, Im sick of the sloopy one I have atm
14th August 2016, 02:34 PM
#28
threedogs
About 30 minutes a side. If I had to do it again it would be quicker. You have to change the receiver on the seat as well because they come as a set.
threedogs (14th August 2016)
