20th December 2016, 06:54 AM
#31
I have a loud squealing coming from the front of a 3ltr I got last wed, driving it home the noise was very concerning but the guy I got the truck off says it was just the fan belt... After doing some reading on the friday I decided to replace the belt along with the idler pulley assembly. Started truck up no noise for about 15 minutes then it started again, If I spray some belt grip on the belt noise goes away. but then returns either a few hours later or when I start it again. any advice or suggestions would be appreciated. Alternator is near new air con doesn't work but I can see the belt pulley turning. If I spray even the smallest about of lube or anything at the back of the fan so it blows over the belts and pulleys the sound goes away....I'm already regretting swapping my 4.2 for this truck...
20th December 2016 06:54 AM
20th December 2016, 08:37 AM
#32
its either your alternator pulley ,tensioner pulley bearing. What brand belt did you fit Gates or OE would be the only choices
20th December 2016, 08:49 AM
#33
Did you replace the belt with an oe
my theory on this is the thickness and
depth of the groves has some effect
on the squeal
other wise its an alternator or
air con bearing
The Following User Says Thank You to Sir Roofy For This Useful Post:
BigRAWesty (20th December 2016)
20th December 2016, 09:28 AM
#34
Belt grip was probably not the best solution for a noisy belt..
Try chalk.
20th December 2016, 12:06 PM
#35
bigguwesty
Try chalk.
agree belt grip is a nasty product in some circumstances
