26th February 2016, 10:18 PM
Please help
My 97 GQ has started doing something very odd, after turning my car off (and taking keys out of ignition) my dash shows like it is in acc. Battery guage still works, the oil light, hand brake light stay on. I thought it might have been a fault in the ignition switch shorting out and giving permanent power but i have tested that theory by removing the fuse and the switch and dash still lights up. I can't think whee else would fault to cause this, ideas? And ways of testing would be very appreciated.
Thanks in advance
Dave
26th February 2016 10:18 PM
27th February 2016, 08:22 AM
Hi Dave,
If you have taken out the fuses and it still lights up it is getting power from somewhere. There must be a crossed up wire there somewhere or a wire has been stripped back. I reckon you are going to have to go searching.
27th February 2016, 12:18 PM
Dave what motor
What fuse did you pull as there are a couple.
Covo is probbly on track, but the motor and fuse details will help
I would still be suspecting the ignition sw
27th February 2016, 02:34 PM
It's an RD28T, i pulled the actual plug off the ignition and the fuse marked as ignition switch (30 amp) in the engine bay.
I'm about to pull out the test light and find which wire in the loom is delivering permanent power.
27th February 2016, 06:58 PM
Well after playing with the test light the only wire showing 12.9v is yellow red on 2 out of 3 plugs for the dash, this wire goes to ignition relay, so ive removed the relay tested again and got 12.7v, removed fuse marked 'meter back L' which according to the diagram comes after the relay, tested again and no power to the dash, do you think it is a wire from the relay to fuse or relay? Any other thoughts?
Thanks in advance
Dave
27th February 2016, 08:38 PM
So I'm almost certain it's a short in the relay holder but there is one problem with that. ....does anyone know how to get into the back of the relays? I've pulled the fuse panel off and the backs of the relays are hidden behind molded plastic with no way to get into them that i could see, what looks like should be screws are shiny round button heads with no way get them out, anyone come across this before?
1st March 2016, 07:13 PM
Well i gave up was confusing me so took it to the mechanics today, turns out previous owner replaced the 10 amp brake light fuse with a 30amp, I'd never had a fuse blow so didn't bother to check previous owner had the right fuses in. ....the reason i was getting permanent power to my dash is because parts of the wiring loom have melted and there is a number of shorts, thinking the best thing to do is replace the whole wiring loom, anyone got one?
The Following User Says Thank You to dave97 For This Useful Post:
5th March 2016, 01:12 PM
Was the brake light on all the time due to a faulty brake light switch under the brake pedal??!!
Otherwise, I can't imagine how the 30amp fuse can melt the wires.
Also, I have never seen a 30amp fuse that would fit into the fuse board.
It might be a good idea to find out the reason behind the melting of wires before you replace them. In other words, find the reason brake light fuse to affect the melting of the wires.
5th March 2016, 02:27 PM
Dash lights were staying on not brake lights, the sparky found a short at the right hand side that must have been the reason the previous owner upped the fuse, I'm replacing the full wiring loom so none of the original wiring will be there, tracked down a full loom in Queensland from front to back.
5th March 2016, 04:02 PM
dave97
So, the damaged wire and resulting short circuit was there before the previous owner "upgrading" the brake fuse?
That makes sense. Obviously, he band aided without searching for the real problem. Not a good approach with electrical problems. Lucky he didn't burn the car down.
