Results 1 to 5 of 5
Thread: Volts & amps in one
    Volts & amps in one
    Heres a little ripper , not sure how many are fans of amp meters,?
    Might be interesting to see what devices pull what amps when working.
    Price is cheap compared to others out there
    http://www.ebay.com.au/itm/VOLT-AMP-...cAAOSwB4NWxOt1
    Think Ill change my Aux battery volt gauge to one
  2. The Following User Says Thank You to threedogs For This Useful Post:
    mudnut (24th February 2016)
    80 Post(s)
    Dunno about accuracy, but good as quick reference.
    330 Post(s)
    Not sure why? this will only measure upto a 10amp load? so no good for measuring Alternator charge. if you have more than a couple of things coming off your aux battery and the draw gets to 10amps this will stop working? anything your running a 30amp relay off will not function with this either?
    I would actually be interesting to wire it into the Fridge plug directly assuming it will read the Fridge Draw? not sure how you would stop it reading all draw off a circuit though? maybe it would need to be a switched circuit from Battery to Fridge only? it must then differentiate between input and draw while driving? I think it has a limited application.
    Id be interested in measuring and monitoring Alternator Output in Amps?? and or Winch Draw in Amps?? Very interested in that.
    80 Post(s)
    Very easy to set up a high current shunt and use connect an ammeter across it, for the winch.
    Example only http://www.ebay.com.au/itm/Amp-Ammet...0AAOSw5ZBWIIo7
    In layman's terms: The ammeter is only a very sensitive voltmeter, that measures the voltage drop created by the current running through the shunt.
  7. The Following User Says Thank You to mudnut For This Useful Post:
    MudRunnerTD (25th February 2016)
  8. #5
    80 Post(s)
    Or a matched set, for reference purposes only while setting up the circuit as it ain't water and muck proof.
    http://www.ebay.com.au/itm/Analog-Am...BQPBidIXhgWDLA
  9. The Following User Says Thank You to mudnut For This Useful Post:
