22nd February 2016, 03:12 PM
#11
Legendary
mudnut
G'day all. i recently replace the 5/8" (16mm) hose from the steering fluid res to the back of the pump with 1/2" (12.5mm) hose because the owner of the shop reckons it is better to stretch a hose 1.5 mm to fit the 14mm barb, rather than try and squash the 16mm hose down.
Since I replaced the fluid with dextron III. I have noticed that the pump is whining.
my questions are: Is the 12.5 hose restricting flow to the pump?
Is the Dextron III incompatible with the system?
I'm guessing you replaced the hose 'cos it was leaking at the joint between barb and hose?
I had that issue. When I removed the hose to have a close look at it, it looked fine. I applied some silicon to the barb and
put the hose back in and tightened the hose clip properly.
It has never leaked since then. Before that, it was leaking for ages.
BTW, original hose comes with a heat shield around it 'cos the power steering hose from reservoir to the pump is way too close
to the exhaust. Make sure to wrap some heat shield around the new hose.
I use power steering fluid. I reckon it's the same as Dex III.
22nd February 2016 03:12 PM
22nd February 2016, 03:57 PM
#12
The hose has gone brittle and cracked, so I cant cut it back and re-clamp it. I went into town, to get some 5/8, but they can't seem to get it. I hope the new hose can withstand suction too. Now I am stranded here, as I don't want to damage the pump, as cavitation can eat through metal.
22nd February 2016, 05:27 PM
#13
I risked at trip into town, as mechanic pointed me in the right direction. I have bought a metre of aeroflow series 400 hose. The salesman reckons it should be OK to use a hose clamp on it. Unfortunately it is blue, but beggars can't be choosers. It is way stiffer than the 1/2" I have on so should resist collapsing under suction.
23rd February 2016, 04:05 PM
#14
Replaced the hose and the whirring noise has died down. I will take it for a drive tomorrow to check it at higher revs.
The Following User Says Thank You to mudnut For This Useful Post:
dom14 (23rd February 2016)
23rd February 2016, 06:12 PM
#15
Legendary
mudnut
Wrap some heat resistant paper or wraps around it. I reckon the reason they go brittle is from the exhaust heat.
The Following User Says Thank You to dom14 For This Useful Post:
mudnut (23rd February 2016)
23rd February 2016, 06:29 PM
#16
dom14
That and the fact it has been on the vehicle for 22 years I used the fibre-alloy wrap and a the standard foam sleeve.
24th February 2016, 08:35 PM
#17
The noise has gone even after the system has been running for ages. I'm sooo heppy.
The Following 2 Users Say Thank You to mudnut For This Useful Post:
BigRAWesty (25th February 2016), nissannewby (24th February 2016)
25th February 2016, 01:27 PM
#18
Did you take the 1/2" line back and slap old mate with it?
25th February 2016, 01:41 PM
#19
Patrol Freak
correct me if i'm wrong but isn't the powersteering on the intake side.... of a td42 or am i special.
25th February 2016, 01:47 PM
#20
