Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Power steering pump noise.
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    G'day all. i recently replace the 5/8" (16mm) hose from the steering fluid res to the back of the pump with 1/2" (12.5mm) hose because the owner of the shop reckons it is better to stretch a hose 1.5 mm to fit the 14mm barb, rather than try and squash the 16mm hose down.
    Since I replaced the fluid with dextron III. I have noticed that the pump is whining.
    my questions are: Is the 12.5 hose restricting flow to the pump?
    Is the Dextron III incompatible with the system?
    North brissy
    Dex 3 should be fine.
    You are likely causing a restriction with the smaller line and causing cavitation (whine). Shouldnt ever down size a suction hose.
  4. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    dom14 (22nd February 2016), mudnut (22nd February 2016)
  5. #3
    SW Vic.
    80 Post(s)
    That is what I thought, but wanted to be certain, thanks Matt.. Bugger, it will be the third time I've had to do the job!
  6. #4
    Thomastown, Melbourne
    6 Post(s)
    I have been having issues with my power steering at idle or when on tight tracks with it getting very difficult to turn... i have to stab the accelerator to get the revs up so i can turn the wheel..
    Matty was driving my car the other night and says his does the same thing. .
  7. #5
    North brissy
    What pulley do you have on yours aftet your conversion?
  8. #6
    6 Post(s)
    Its all td but mudski thinks its worn as i have to run smaller belts
  9. #7
    North brissy
    Quote Originally Posted by Bloodyaussie View Post
    I believe the tb ones are smaller which may help of you want to give it a try. Its basically just a flow vs rpm thing
  10. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (25th February 2016), dom14 (22nd February 2016)
  11. #8
    The master farter
    mudski's Avatar
    465 Post(s)
    Your pulley has scolloped out Jonathan. Mine has too, but only slightly.
    A smaller pulley as Mat said or the pump may need a new cartridge kit in it. I got them but they're not bloody cheap. I wonder if there is a way to test the pressure of the pumps. Assuming there would be...
  12. #9
    6 Post(s)
    My idle is much lower than it was with the other engine. .. sits around 620rpm i think.... ?
  13. #10
    North brissy
    Easy to test them with the right gear.
    Td42 idle should be 750rpm
  14. The Following User Says Thank You to nissannewby For This Useful Post:
