Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: DIY -Ryco A360 flat panel airbox with 4" in/out
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I've just made my own flat panel airbox with 4" in/out and thought it might interest some of you.
    For space reasons I chose the Ryco A360 air filter. This is standard on some old VN & VS Commodores and also the GQ TB42E and some Nissan Skylines.
    I got a 600 x 600 x 1.6mm sheet of mild steel from Bunnings and a couple of 4" mandrel bends from Ebay but only used cuts from the 45 degree.
    I can't weld aluminium so I'm making it all in mild steel and welding with a MIG.
    Made a mockup from card board.
    Drew it on the steel plate and plasma cut it with my little Ebay cutter.
    Bent it into shape.
    Then I made the lid. The shape was decided by the height to fit under bonnet and the A/C & steering hoses.
    Welded on the outlet pipe and did some trial positioning.
    I then welded a 15x3mm skirt around the lid that serves as the lip that tightens down onto the filter edge.
    Welded some fixing tabs and painted it all ready to go.
    All bolted in.
    Cost came out under $200 including steel, A360 element and silicone hoses & clips
    I still need to cut a bigger opening in the inner guard to have a 4" elbow coming through.
    I plan to retain the current Nissan snorkel.
    John
  2. The Following 12 Users Say Thank You to jff45 For This Useful Post:
    Bloodyaussie (17th February 2016), clubbyr8 (19th February 2016), Clunk (17th February 2016), gaddy (17th February 2016), Hodge (17th February 2016), jay see (17th February 2016), MudRunnerTD (17th February 2016), mudski (17th February 2016), NissanGQ4.2 (6th April 2016), SiberianPatrol (17th February 2016), Sprock (18th February 2016), threedogs (17th February 2016)
    Wicked!!!!!
    jff45 (17th February 2016)
  6. #3
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    thats a shit hot job mate. Very impressive
    Lucus30's 1999 GU ST TB45E
  7. The Following User Says Thank You to lucus30 For This Useful Post:
  8. #4
    Very very nicely done!
    Wish I could weld.
  9. The Following User Says Thank You to Winnie For This Useful Post:
  10. #5
    Sep 2013
    16 Post(s)
    Welcome to come round here any time and learn. I'm new to welding myself
  11. #6
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Where abouts did you get the 4" pipe from? Have a few ideas rolling around in my head that I want 4" pipe for
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  12. #7
    Morayfield, QLD
    As I mentioned above, metal sheet from Bunnings and 4" mandrel bends from Ebay..
    John
  13. The Following User Says Thank You to jff45 For This Useful Post:
    lhurley (17th February 2016)
  14. #8
    That is truly a great looking piece of work.
  15. The Following User Says Thank You to mudnut For This Useful Post:
  16. #9
    Thomastown, Melbourne
    6 Post(s)
    Top notch as always mate.
  17. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  18. #10
    Sep 2013
    16 Post(s)
    Bent it into shape.
    All bolted in.
    Actually I just noticed something very wrong in these photos
