Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: URGENT HELP - removing front shock bottom nut
    Jan 2014
    Shepparton VIC
    Hello All,
    Any help on removing the bottom nut of front shocks.
    All (front and rear) nuts came off easily but the front bottom nuts.. any ideas please.
    Thanks with regards
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
    North brissy
    Rattle gun
  4. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (16th February 2016), MyGU8 (16th February 2016)
  5. #3
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Rattle gun
    Or if that doesn't work a breaker bar and bit of pipe over it lol..
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
  7. #4
    Jan 2014
    Shepparton VIC
    Rattle gun
    Yep I wish I have one....!!!!!
    I think the only way is pipe wrench....!
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  8. #5
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    hammer the breaker bar
  9. The Following 2 Users Say Thank You to garett For This Useful Post:
  10. #6
    Legendary happygu's Avatar
    2 Post(s)
    You can put a shifter on the bottom flats, to hold it from spinning, or you can put stillson wrench on the bottom of the shocker itself where the weld is at the bottom - to hold it from turning and undo the nut.
    Worst case scenario, is to cut the bottom nut with a hacksaw from the bottom up the the base of the nut - just wide of the thread and it will then just undo easily, as the nut will stretch and spread.
  11. The Following User Says Thank You to happygu For This Useful Post:
  12. #7
    Quote Originally Posted by happygu View Post
    that tends to happen as you get older
  13. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    mudski (16th February 2016), threedogs (18th February 2016)
  14. #8
    The master farter
    mudski's Avatar
    462 Post(s)
    I thought they would just stretch and hang... Not spread. Lol
  15. The Following User Says Thank You to mudski For This Useful Post:
    Clunk (16th February 2016)
  16. #9
    Jan 2014
    Shepparton VIC
    May be both.....
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  17. #10
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    How did you go?
    Lucus30's 1999 GU ST TB45E
