16th February 2016, 07:50 PM
URGENT HELP - removing front shock bottom nut
Hello All,
Any help on removing the bottom nut of front shocks.
All (front and rear) nuts came off easily but the front bottom nuts.. any ideas please.
Thanks with regards
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
16th February 2016 07:50 PM
16th February 2016, 07:54 PM
BigRAWesty (16th February 2016), MyGU8 (16th February 2016)
16th February 2016, 07:59 PM
nissannewby
Rattle gun
Or if that doesn't work a breaker bar and bit of pipe over it lol..
nissannewby
Rattle gun
Yep I wish I have one....!!!!!
I think the only way is pipe wrench....!
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
16th February 2016, 08:03 PM
The Following 2 Users Say Thank You to garett For This Useful Post:
16th February 2016, 08:12 PM
You can put a shifter on the bottom flats, to hold it from spinning, or you can put stillson wrench on the bottom of the shocker itself where the weld is at the bottom - to hold it from turning and undo the nut.
Worst case scenario, is to cut the bottom nut with a hacksaw from the bottom up the the base of the nut - just wide of the thread and it will then just undo easily, as the nut will stretch and spread.
The Following User Says Thank You to happygu For This Useful Post:
16th February 2016, 08:17 PM
Dribble Master
happygu
that tends to happen as you get older
The Following 2 Users Say Thank You to Clunk For This Useful Post:
mudski (16th February 2016), threedogs (18th February 2016)
16th February 2016, 08:20 PM
Clunk
I thought they would just stretch and hang... Not spread. Lol
Clunk (16th February 2016)
16th February 2016, 08:28 PM
mudski
May be both.....
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
16th February 2016, 09:18 PM
Hardcore
Lucus30's 1999 GU ST TB45E
