Results 1 to 6 of 6
Thread: ECUTalk and routing the Cable
    Aug 2014
    Perth
    10 Post(s)
    Hi All,
    Seems pretty popular to have the gauge sitting in front of the steering wheel I am wondering where and how you have routed the cable down to the male socket by the fuse box. Show me your installs.
    Fish
    just taped under the steering wheel and into the OBD2 port cant see it.
    Just used some 3M double sided pressure sensitive tape to fix it
    gubigfish (13th February 2016)
    43 Post(s)
    That's the plan with my scangauge TD. Pretty sure growler has his up near his pillar.
    In this position you can still see all the glow lights and other warnings.
    You can not see you mileage or that stupid clock.
    BigRAWesty (14th February 2016)
  8. #5
    Expert Wetty's Avatar
    South Guildford WA
    I've got mine velcroed just above the demisting vent on the dash under the pillar gauges, it's easy to read there and out of the way. I ran the cable under the pillar cover then on the inside of the dash where the door closes against it.
    Andrew
  9. The Following User Says Thank You to Wetty For This Useful Post:
  10. #6
    Quote Originally Posted by Wetty View Post
    Andrew
    I just ran some cable yesterday from the dash down under the steering,
    If you pull the A pillar door rubber off there is a cavity there to run some cable.
    Neat as and you never see the cable
