Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Interchangable Ute Trays
    472 Post(s)
    G'day NP.com.au,
    I'm hoping somebody out there may know where to buy these things in Australia, hopefully Victoria if possible?
    http://www.buyersproducts.com/truck-...ated-pin/1153/
    Cheers MB !
    Give Scotty a buzz @ Trailer Parts in Tullamarine, 93355822
    He sells heaps of gear to make your own trailers etc.
  4. The Following User Says Thank You to threedogs For This Useful Post:
    MB (9th February 2016)
  5. #3
    472 Post(s)
    Legend John,
    Thanks heaps mate, Scotty has them in all varying sizes.
    I'll drop in and see him later this week.
    Cheers Mark !
  6. #4
    happy to help lol
    Scotty's is the man for all trailer gear
    He's just next to All Tools on the right hand side
    of Garden drv
    "Master Castors"
  7. The Following User Says Thank You to threedogs For This Useful Post:
  8. #5
    For anyone else reading this thread, Master Castors and trailers will also do custom axles
    with or without brakes. I brought my Orac off road greasable suspension for my trailer
    from Scotty, 10" electric brakes as well
  9. The Following User Says Thank You to threedogs For This Useful Post:
  10. #6
    472 Post(s)
    Finally found a couple of hours 'shed-me&me ute project time' this arvo :-) ! The mock-up seems to be working well, rusty I know, a hot gal bath later will fix that ! Cheers 3D, I'll touch base with Scotty again later this week to collect the final bits needed :-) !!
  11. The Following User Says Thank You to MB For This Useful Post:
    AB (17th July 2016)
  12. #7
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Gunna make it a tipper??
    472 Post(s)
    Damn you Westy :-) ! My anxiety is high enough with overthought as is :-) ! YES, I guess I should make another tray too, grouse (Vic :-( ) fun !!!
    Plan was to cut down several 'trailer' rego's and have Santa Sled's for all property needs.
    * 1 x tonne water skid
    * 1 x 1/2 tonne spray kit
    * 1 x Harland/Russian transfer pump
    * 1 x Touring/Work tray
    * 1 x HC short corner cut weekend tray
    * 1 x Tipper tray now :-)
    Cheers Westy :-)
    BigRAWesty (17th July 2016)
  15. #9
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Cheers Westy :-)
    Imo save your time and cash..
    Make a good solid tip tray.
    Then build a touring canopy to fit it.
    And frame to house the spray unit etc etc..
    After the first change you'll think fark this and just leave the tipper on..
    And in all honesty your only a couple hundred kilos worse off....
    If I knew you were building I would have taken some picks of out yota tip tray on the farm for ya..
    Very simple.. and hydraulic..
  16. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MB (17th July 2016)
  17. #10
    472 Post(s)
    Cheers Westy, agreed :-) !
    If it were my old GU single cab then for sure!!
    The Laingley extra cab sends heaps of load counterlevering back so whatever weight saving I can achieve is gold :-)
