10th February 2016, 02:22 PM
#11
Travo
Good tip Threedogs I put the original filter back in and had a look at some of the hoses and was thinking same, what are the standard sizes and I will just get a couple of meters of each to start with.
I have an LRA belly tank, would they have used the standard patrol pump in this set up?
Travo
LRA tanks use an intank electrical pump, specific for that, usually. Sender unit might be the same since it has to match with the existing dashboard gauge electrics. But, I reckon the LRA intank pump might be different from the original one.
They do develop problems over time, but I'm guessing, most of those fuel pumping problems are related to connections getting weaker over time, rather than pump itself. I have a similar issue atm, which I'm about to diagnose once for all by dropping the LRA tank in mine(RB30, carby). The best way to diagnose whether your issue is fuel pressure related is by checking the fuel pressure with a gauge. Fuel pressure tester is a cheap unit you can by off fleabay. It usually doubles as vacuum tester as well.
http://www.ebay.com.au/itm/10-PSI-Ca...wAAOSwo6lWJJky
Fuel pressure can be different between carby & EFI models, as well as turbo and non-turbo engines.
Follow these video guides on how to do the test.
https://www.youtube.com/watch?v=AeVTZz0od7Y
https://www.youtube.com/watch?v=_oXLUqE4Sf0
Refer the Haynes manual(which can be downloaded from here) section 4(Chapter 4) Part B, page 2 and 3(4B-2 and 4B-3) or PDF page 12 & 13 of of the section 4(chaper 4) of the Haynes manual.
Pay a bit of attention to the fuel pressure regulator. That might be the cause of the issue.
10th February 2016 02:22 PM
10th February 2016, 04:58 PM
#12
95% sure that the feed and return lines are 8mm on a tb42e and 1/4 for the breather to the charcoal canister
The Following User Says Thank You to billyj For This Useful Post:
dom14 (10th February 2016)
11th February 2016, 03:37 PM
#13
Just had a chat to LRA and the pumps for the tank are the standard Patrol unit.
Might grab spare anyway as the car has done 300,000k's.
Travo
25th April 2016, 08:55 AM
#14
25th April 2016, 11:36 AM
#15
My daughter's tb42e had random problems like this, did turn out to be the fuel pump. It appears that it doesn't take much drop in pressure for them to do strange things
The Following User Says Thank You to rods gq For This Useful Post:
