Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Buying a welder.
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Buying a welder.
    Need some advice from the experienced.
    I want to buy a welder and start working more with making different stuff but unsure of what to buy or need.
    I am not flushed with cash so not to expensive.
    Can you get something to use on different gauges or types of metals?
    Used to do a ton of mig welding and silver soldering around 20 years ago but lot of things changed.
    Any ideas appreciated.
    80 Post(s)
    I love my Tig/stick welder, but it is a bit small for larger jobs as it is limited to 80 amps. It is brilliant on panel work.
    I have a few welders a MIG an old Transarc CIG and a very light inverter welder.
    I find I use the inverter more, but I love stick welding , Mig allows anyone to
    call themselves a welder,
    All depends what you want to build IMO
    Dec 2012
    Coffs Harbour
    Thanks TD. Don't want to build anything specific but have found more and more often that I have an idea in my noggin and want to have a crack at it but can't. Different things so that is why I was asking if you can use on different metals or do you have different welder for different jobs?
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I just bought a unimig 175. Seems to lay a bead nicely even for a new welder like myself.
    Lucus30's 1999 GU ST TB45E
    Trouble with MIG for the DIYer is the rental and cost of the bottle of Gas,$$$$$$$
    I have gasless wire but its not up to par with a MIG weld. For any square tube welding
    an inverter would work well, if youre doing a dual cab chop then hire a bottle and mig weld it
  8. #7
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    I have a cheap cig weld 145 amp mig. Runs mig and flux core wires.
    Not amazing but does well for sticking things together and odd fix up jobs.
    If you want to weld other metals (not just mild steel) then you should look into a tig/stick welder. Tig requires gas but that could be saved for bigger jobs and the stick can be used for quick little jobs.
  9. #8
    Nov 2014
    Waikiki, WA
    My old CIG Transarc stick was getting tired so began looking around for a new welder. One that would be handy in the shed and one that was small light weight and could be taken away on our prospecting trips and be run using our Honda 3kva inverter generator.
    This one works a treat.
    http://www.ebay.com.au/itm/NEW-Misht...YAAOSw-W5Utx2~
    Strangely if I switched off the generator "economy" and struck an arc the welder tripped after a couple of seconds.
    Switched back to "Econ" struck an arc generator came up to revs and the stick burned away.
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
  10. #9
    Expert billyj's Avatar
    gordon
    3 Post(s)
    check out power 10 gases, avalible through total tools + bunnings if my memorys right, you buy the bottle outright then just swap and go when empty like with bbq gas
  11. The Following User Says Thank You to billyj For This Useful Post:
    Covo71 (8th February 2016)
  12. #10
    Dec 2012
    Coffs Harbour
    Quote Originally Posted by Nightjar View Post
    I am liking the price a lot at $139. It might be a winner.
