Results 11 to 20 of 26
Thread: Knock in front end when turning left or right.
    Expert Wetty's Avatar
    South Guildford WA
    Bit hard 2 see in the pic but the bolt holes on the diff bracket are elongated, like Kallen has suggested
    Attachment 64626
    Just loosened the nuts and checked the holes. . . . and what do you know, I have elongated holes, about 1mm on each side! My next question now is, how do I fix them? I was thinking of getting some heavy duty washers the same size as the bolt and welding them to the hangers, but then I'd need longer bolts to account for the washers.
    Andrew
  2. The Following User Says Thank You to Wetty For This Useful Post:
    BigRAWesty (6th February 2016)
    43 Post(s)
    Quote Originally Posted by Wetty View Post
    Andrew
    Grab some weld on washers from threedogs.
    You'll need 8 and 4 new m16 grade 8.8 bolts 110mm long preferably in a metric fine thread..
    Remove bolt, insert a washer either side, tighten and the weld them on..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Wetty (6th February 2016)
  6. #13
    Oct 2015
    have you checked the CVs
  7. The Following User Says Thank You to Dorizzi88 For This Useful Post:
    Wetty (7th February 2016)
  8. #14
    Thomastown, Melbourne
    6 Post(s)
    Like i said.... nearly always radius arms.
  9. The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
    BigRAWesty (6th February 2016), Wetty (7th February 2016)
  10. #15
    Or body mounts.... but not n this case lol
  11. The Following User Says Thank You to Clunk For This Useful Post:
  12. #16
    South Guildford WA
    Well, I welded some steel plates to the front holes for the radius arms today, but my clunk is still there, albeit not as loud and not as noticeable through the floor pan . . . . . looks like I will be checking the rear holes now, and if that doesn't work I'll just drive around with the stereo up full noise so I can't hear or feel it
  13. The Following User Says Thank You to Wetty For This Useful Post:
    Clunk (19th February 2016)
  14. #17
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    haha thats been my solution for the car i sold... didn't want to fix it
  15. #18
    also maybe check the shocks rubber bushes if you cant find anything else
  16. The Following User Says Thank You to threedogs For This Useful Post:
    Wetty (20th February 2016)
  17. #19
    Jan 2015
    19 Post(s)
    i got rid of alot of noises by replacing spring pads. mine were worn through
  18. #20
    South Guildford WA
    Did that too, drivers side was gone and squeaked every time I got in the thing. . . . the knock is definitely on the passengers side so I'll check it out when my body recovers from lying on the concrete with spanner in hand!
