Results 1 to 6 of 6
Thread: RB30 guys
    Patrol Guru
    Jul 2014
    6 Post(s)
    RB30 guys
    Hey rb30 guys, wondering what you set your timing at. Running straight petrol. Also, when you set it do you do it with the vac advance unplugged?
    I've done it before and it runs fine, but figured I'd just see what everyone else does.
    FWIW, I know the factory procedures, so just seeing if anyone differs from that.
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    I set my timing as per instructions after the head gasket was replaced. The machining of the head meant the compression ratio changed slightly and the engine was detonating. I took it to the Dyno guy and he changed it a fair bit.
    EDIT, while on the dyno, he timed it with the advance still connected.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (4th February 2016)
  5. #3
    Legendary dom14's Avatar
    Somewhere inside Victoria, Australia :)
    38 Post(s)
    AFAIK, vacuum advance should be left connected & the engine should be warmed up to normal temperature before adjusting the ignition timing.
    RB30, some 2-3 inch lift auxiliary LPG tanks
    Few more mods on the way
    http://www.worldwildlife.org/species/tiger
    https://www.panthera.org/
    Cheetah Outreach
  6. #4
    Patrol Guru
    Jul 2014
    6 Post(s)
    Quote Originally Posted by dom14 View Post
    AFAIK, vacuum advance should be left connected & the engine should be warmed up to normal temperature before adjusting the time.
    Hmm interesting. Any idea what timing you guys are running? Pretty sure I'm are 12btdc at idle with vac connected from memory.
  7. #5
    SW Vic.
    80 Post(s)
    From what I remember, The timing is retarded by 12 degrees from standard.
  8. #6
    38 Post(s)
    Mine is 10 BTDC atm. But, I tend to fiddle with it depend on the weather, changing couple of degrees either way.
    I'm not sure whether it makes any sense, but I keep experimenting with it.
    My RB30 cold idle is around 500-600 atm, which I'm pretty sure has a lot to do with the carby, which I haven't got around to adjust it yet. Once it's warmed up, it goes to 800-900.
    Cheetah Outreach
