5th May 2018, 03:18 PM
#181
BUMP!!
Any new info on this? Has anyone successfully managed to get 35's certified in Vic?
I'm looking at getting a cert for my 3" lift and 35's after my latest run-in with the Vic High Country troopers!
I've made a few phone calls to the VASS list and have seemed to get the run around. Finally found one place that will book me in for an initial inspection. If that falls through I'd prefer to try someone that you guys can recommend.
(Have read this entire thread and see that 4x4 Obsession and Engleman are mentioned favourably, but I don't see them on the VASS list?)
5th May 2018 03:18 PM
5th May 2018, 05:32 PM
#182
You won’t get anything larger than a 33 engineered on a Y60 or Y61 Patrol period. Unless you spend 20k for portal axles then you can. Only. Use VASS approved engineers too. The police and Vic roads cannot argue with their compliance. Use a non vass approved engineer, they can.
I use 4x4 Obsession for my cert. he even did a pre inspection before I booked it in to give me a heads up just in case.
5th May 2018, 05:47 PM
#183
VASS certification for portals will cost you around the 6K mark for a GQ. Thats what I was quoted when I looked into it for mine. Marks 4x4 never put the GQ through second tier certification, hence why the GQ punter has to go the extra mile. The GU however has been fully certified, so the 22K number stands as Mudski said.
6th May 2018, 09:49 AM
#184
PeeBee
So it’s an extra 6k on top of the cost of the portals instal? Yikes!
6th May 2018, 11:52 AM
#185
mudski
Yep, and this was from the only VASS engineer who would take it on. Brake and swerve test need to be done, plus 'who knows what'.
7th May 2018, 04:16 PM
#186
PeeBee
Seems a bit of a rort to me to be charging 6k for an engineers cert for Portals. I know theres more involved but...
7th May 2018, 04:40 PM
#187
Yep, after seeing the hoops I had to jump thru, then the actual level or 'engineering certification' which essentially was a visual inspect then the brake test, 6k is rediculous but if you want the toys you gotta pay, or run the gauntlet and end up with something that cant be driven on the road legally or only at night - anyone come to mind?????
7th May 2018, 04:42 PM
#188
PeeBee
*cough* Darren!!!! *cough*
7th May 2018, 04:43 PM
#189
cough, cough, seems I have caught what you have!
7th May 2018, 06:40 PM
#190
Question is it really worth doing all these mods , Portals etc
would money be better spent on a top of the line Duramax and two lockers??
Just saying must be getting old maybe ha ha ha
