Page 8 of 23 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 224
Thread: Vehicle Engineers reports, 4WD Modification rules, whats allowed, what not...
  1. #71
    462 Post(s)
    When I was taking to the engineer in Adelaide I'm pretty sure he said he will do 35's as the only requirement it need to meet is the speedo within legal spec.. so between 0 and -10% of a GPS. .
    So if your running 4.3 diffs and a speedo adjustment gear you should be right..
    That was about 2 years ago though..
    Things may have changed..
    A $50 speedo gear is all thats needed to correct that then. .
    Tyre roll on a 35 is the major concern when doing the swerve test i was told by the engineers here. Plus its written in black and white in the rule book one said too. It is in one of the links in the op, i think. Man if theres a loop hole or a way, I'd be on it. Cost depending of course. Lol.
    Really. As long as my car is engied for everything else, i wont worry about the 35s and just cop a minor defect notice which is easy to get cleared.
    43 Post(s)
    Gotta remember that good old dividing line between us which the rules magical change..
    So what you may have to jump threw hoops to get I may just need a gear lol..
    Imo Ill be keen to get my 33's done..
    From memory $600 a certify..
    462 Post(s)
    Do you need to get 33s done in SA?
  5. #74
    43 Post(s)
    Yep. Were allowed 7mm tyre increase..
    So basically tread wear..
    And 50mm lift
    462 Post(s)
    And 50mm lift
    That sucks.
    BigRAWesty (26th May 2016)
  8. #76
    43 Post(s)
    That sucks.
    Sure does..
    49 Post(s)
    Not always the case.
    When AB and I got picked up they were doing us a favor by not issuing the $400 fine and demerit points and its at their discretion if they hand out a minor of mayor defect.
    When are you going to 4x4 obsission? Call in while your up my way. I'll have the coffee on........
  10. #78
    462 Post(s)
    From my understanding. If the fuzz only get you for one defect they cant issue a canary. As its three defects needed for this.
    I could be wrong but thats what i am led to believe. Happy to be proven wrong
    When you got done and copped the canary its because the tyres you had weren't load or speed rated and are pretty much bait. Lol
    Ill have no ride to when i drop the car off. So unless your in walking distance....
    jay see (27th May 2016)
  12. #79
    Jul 2014
    6 Post(s)
    Hey mate, I get your thinking, but one important thing is that none of it really matters. The police don't need to know exactly what's what.. They could say your accelerator pedal looks worn, the numbers on your gear stick aren't visible enough and your rear seatbelt doesn't retract fast enough - and you could take it for a rwc and pass all of these things with no issue - it won't stop them from giving you a yellow sticker if they want to. FWIW, I'm with you and I run the gauntlet myself. Thankfully only been done once for tyres and lift, was a minor and only an inspection required (had to change lift/tyres of course, but that's no biggy). My point being, if they want to get you, they will.
  13. The Following 2 Users Say Thank You to Throbbinhood For This Useful Post:
    jay see (27th May 2016), mudski (27th May 2016)
  14. #80
    462 Post(s)
    Plicks they are!
  15. The Following User Says Thank You to mudski For This Useful Post:
