Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: fuel problem
    Beginner Bush pilot's Avatar
    Feb 2015
    in Deux-Montagnes, Québec Canada
    fuel problem
    Hi every body, I have a Nissan Safari 1991 Y60 diesel for now 5 years. I have speed problem, the engine stop an run au 85 kl., to fixe the problem My mechanic man
    told me to install a low pressure pump on the intake fuel line. That was working for about 4000KL, and the problem his back. I change fuel filter every 4000 to 5000 KL.
    Tell me if I am wrong or not but I really think the real problem it is the fuel tank, is that possible their is sluge or mud in the tank?
    I have only 116500 KL on the Safari it is a 2 dors model right hand drive.
    I am a new member on Nissan Patrol, thanks you to exist, I really need help. In Canada Nissan Safari is not very popular, on the road everybody turn the head to put their eyes on the truck.
    Regards Robert
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by Bush pilot View Post
    Regards Robert
    First would be to check that the low pressure pump is still working I would think. If that fixed it before it may be blocked or not working now. Check filters for contamination as well.
  4. The Following User Says Thank You to 4bye4 For This Useful Post:
    Bush pilot (2nd February 2016)
  5. #3
    North brissy
    Check the inlet to the injector pump. Some have a small gauze filter. You will need small hook to get it out. Usually there is a spring that sits on top of thegauze filter.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
  7. #4
    Feb 2015
    The low pressure pump working very well, the fuel filter was black inside, when i take off fuel filter i put the fuel over flow in transparent bol and the fuel was black?? I think i have to clean the tank.
  8. #5
    Feb 2015
    Yes the small gauze filter was check pass 3 weeks by my mechanic man. he was ok.
  9. #6
    Feb 2015
  10. #7
    Aug 2014
    Kingsley WA
    15 Post(s)
    Fuel is black - yep recon you should clean the tank. in fact clean the entire system. from another website;
    SUSPENDED PARTICULATE MATTER
    Dirt, rust or oxidised fuel may form a fine suspension of brown or red particles,
    causing a greasy black deposit on the fuel filter. Laboratory analysis of the filter and
    fuel may be required to establish the cause. Resolution of the problem may require
    change of fuel and/or improved fuel storage management.
    http://www.bp.com/content/dam/bp-cou...problems-1.pdf
  11. The Following User Says Thank You to 4bye4 For This Useful Post:
  12. #8
    Feb 2015
    I just go on you web reference, it is really look i have contamination in my tank. Some one have and idea how to clean inside tank??
  13. #9
    I would think the easiest and best way would be
    to remove the tank and give a good internal scrubbing.
    Might want to replace the fuel line as well it wouldnt
    break the bank IMO
  14. The Following User Says Thank You to threedogs For This Useful Post:
  15. #10
    Feb 2015
    what is the bank IMO?
