Nissan Patrol GU front brake calipers rotors pads backing plates and master cylinder
Removed from a 2001 GU Patrol after a full brake upgrade was done.
The LH rotor was rebuilt around 18 months ago, the RHS not. I have the other half of the kit here. The rotors are dimple drilled and slotted RDA rotors. These are barely 12 months old.
The pads are Bendix 4wd pads are about half worn. And the standard master cylinder, No leaks, worked perfectly prior to removal.
I can rebuild both calipers (at the buyers expense) if they wish. But its not hard to do yourself.
Pickup is Mill Park ,victoria
Can post...
Any Q's get me on 0488-387666
List Date: 1/31/2016
For more info, click here to view the original listing: Nissan Patrol GU front brake calipers rotors pads backing plates and master cylinder
This item is no longer available.
