12th August 2016, 11:11 PM
altech
That's awesome thanks.
Will make contact with them and do the same install as you have.
Not sure what difference the 2012 is over your model. Will soon see.
Have you used your yet and if so how did everything go.
I assume it makes no difference not having a bar and just the winch?
12th August 2016 11:11 PM
14th August 2016, 01:14 PM
rusty00
Hi Rus , No haven't use it as yet , the Bar is there for Non bull bar fitting , So if have a fitted bull bar that has winch candle built in. and just a Note : if you read on the winch Bar web site , right at the end of bar info , there's a line that mentions about not being Airbag compatible. cheers Alex
