Results 1 to 10 of 12
Thread: hidden Winch install
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, got around to fitting a Winch to the GU as you can see by pic's it was pretty much easy ,but making it all fit wasn't to hard in all around 4 hours ..
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  2. The Following 7 Users Say Thank You to altech For This Useful Post:
    Bloodyaussie (1st February 2016), garett (31st January 2016), MudRunnerTD (31st January 2016), NissanGQ4.2 (31st January 2016), Rock Trol (31st January 2016), rusty00 (21st March 2016), threedogs (31st January 2016)
    462 Post(s)
    Bloody hell. Nice job. Well done.
    altech (1st February 2016)
  6. #3
    Mar 2013
    NE Melbourne
    Very neat.
    Where did you get the winch cradle from? Is it 6mm or 8mm steel?
  7. The Following User Says Thank You to Rock Trol For This Useful Post:
  8. #4
    Very neat job indeed
  9. The Following User Says Thank You to Clunk For This Useful Post:
  10. #5
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by Rock Trol View Post
    Very neat.
    hi Rock, Ebay $295 and 8mm , pretty heavy too. cheers Alex
  11. The Following User Says Thank You to altech For This Useful Post:
    Rock Trol (14th March 2016)
  12. #6
    Mar 2016
    That looks neat!
  13. The Following User Says Thank You to 88WAH For This Useful Post:
    altech (16th March 2016)
  14. #7
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Put a hinge on your number plate and put it back in the middle and no one would know it was there - until you needed it!
  15. The Following User Says Thank You to BillsGU For This Useful Post:
  16. #8
    Very nice,,,,,,,, I think they used springs on the Hinges
    You could drill and fit and eye nut or bolt to store the hook.
    Just saying
  17. The Following User Says Thank You to threedogs For This Useful Post:
  18. #9
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Quote Originally Posted by altech View Post
    Hi Altech, Do you know the eBay supplier for the cradle?
    2012 GU8
  19. #10
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by rusty00 View Post
    Hi Rus, Sorry not from Ebay , i just did Google search and I think I use this supplier - http://www.nissangupatrol.com/produc...alloy-bullbar/
    Or there are some ebay ones too http://www.ebay.com.au/itm/GU-Patrol...kAAOSwx-9WubR6
    http://www.ebay.com.au/itm/GU-Patrol...4AAOSwECZUrGM5
    http://www.ebay.com.au/itm/GU-Patrol...7YP6UTievn59lQ
    pretty sure there are the same Guy , hope this helps cheers Alex
