Results 31 to 34 of 34
Thread: GU centre console removal
  1. #31
    462 Post(s)
    Nice glove box @Cuppa. Where you buy that from?
    174 Post(s)
    Not sure, it was either the Cuppski Corporation or the Mudpa Association.
  4. #33
    462 Post(s)
    I like the sound of Cuppski Corp. I will look them up.
  5. #34
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Thanks Mark & Mike, have just ordered one from my local Jaycar outlet. New model - will take 3 days to get it in. Comes with panel & surface mount & looks like it should fit the same as the existing one.
    Older model with same 4.2a output is on special at the moment, but I wasn't sure if it had the same mount as my existing one - so paid a bit more for the new one which does. Probably a good buy for anyone who doesn't need the extra 'plastic surround' though.
    Photo of my existing one, just 'cos I'm not sure which is the 'Panel' mount, & which is the 'Surface' mount, although I'm guessing mine is 'Panel'.
    Attachment 72251
    Both "should" fit your existing panel by the looks of it. Same screw type mount on the back judging by the pics.
    I had the older type which works well. Stuck it in the back for the 3rd row seat.
    The other ones i have are the carling switch lookalike ones which are mounted where the rear ash tray used to be. Both types work well imo
    2002 GUIII Ti 4.8
    Details here
