31st January 2016, 10:36 AM
GU rear swaybar dbush are these worn...?
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
31st January 2016 10:36 AM
31st January 2016, 10:58 AM
Patrol Freak
can you push the sway bar from side to side ? if you can push it they are worn
The Following User Says Thank You to garett For This Useful Post:
MyGU8 (31st January 2016)
31st January 2016, 11:27 AM
Push and pull with reasonable force may be about one mm of movement in swaybar with some screeching noise, otherwise it is tight.
This is when the car is on ground (not sure whether jacking is required?).
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
31st January 2016, 11:50 AM
Patrol Freak
take it off and wrap a couple turns of http://www.supercheapauto.com.au/onl...ecommendations
if you dont want to replace em. or to diagnose a noise when your driving. ( did it to my car lasted 3 years then i sold it still tight)
sounds like their not terrible but starting to wear. another sigh is it will be shiny next to the bushes this would indicate it has been moving for awhile.
31st January 2016, 04:27 PM
The master farter
escix
If they are making noises when you twist the bar, just apply some grease inside the rubber. Seems to me your rubbers are fine otherwise.
1st February 2016, 02:48 PM
A little slop in them won't matter..
More flex lol..
Unless they are knocking I wouldn't bother
