Results 1 to 10 of 10
Thread: RB30 EFI Conversion
    RB30 EFI Conversion
    This thread is specifically for those who have, or wish to convert their RB30S carby to an EFI set up.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (1st February 2016)
    Jan 2015
    Rb30 efi conversion
    slow internet warning!
    for those who have forgone carburetion:
    You'll need these components for EFI:
    Map of ECCS (advanced technology at the time)
    A chart of the inputs and outputs of the control unit.
    fuel system. this is an r31 skyline diagram
    very simplified air flow diagram. F.I.C.D stands for Fast Idle Compensating Device, it's what kicks in when the AC is turned on, to compensate for the extra load. the air regulator is like a cold start valve, it allows extra air to be put in to raise the idle. some people refer to it as the "electronic choke" but the control unit adds more fuel, the air regulator just adds more air for idle speed (more air past the closed throttle body). it has a bit of influence over the air flow meter too
    The crank angle sensor (CAS) and air flow meter (AFM) aren't bulletproof parts. if the engine just refuses to play nice, these two can be the culprit. CAS lives inside the distributor
    the all-powerful AFM
    more stuff, I adjust throttle valve switches (throttle position sensors) by taking off the connector, loosening the adjustment screws, putting a multimeter set to resistance across the top two pins, and setting it so when the throttle is open slightly the resistance changes. (this is for manuals, automatics have about 6 positions of resistance so need a more complicated adjustment)
    stuff
    more stuff, oxygen sensor, if your car is fine enough but is just running rich and using too much fuel, pull this guy out, he might be fouled or just worn out. you can't clean any carbon off these, they always need replacing ~$110 bursons retail
    injector control
    timing control
    idle speed control
    fuel pump control
    basic diagnostic chart for driveability
    expanded
    another chart
    startability
    self diagnosis. early self-diagnostic technology, useful, but it's not absolute gospel. can be handy for AFM and CAS codes
    how to do it
    i've got more from this book, i'll have to sort through it
  5. The Following 6 Users Say Thank You to pat in a troll For This Useful Post:
    dom14 (10th July 2015), gqsurf (20th May 2016), justy (23rd September 2017), mudnut (4th July 2015), Patrol'n (4th January 2016), Throbbinhood (1st February 2016)
  6. #3
    With regard to bolting on a turbo and engine compression, I talked to the local Dyno guy.
    For a low boost engine, all that should be needed is low comp turbo pistons (concave or spoon crown) and a turbo compatible camshaft.
    As the RB30 bottom end is strong, then the original rods should be ok. Using thicker head gaskets is not a good option.
  7. #4
    Jul 2020
  8. The Following User Says Thank You to Mrbil For This Useful Post:
    mudnut (19th July 2020)
  9. #5
    Jul 2020
    on the vl loom there will be a 4 pin plug bellow the manifold near the bat. connect the 2 orange wires directly to the +12V side of bat. this will provide constant power to wire #1 in picture.
  10. The Following User Says Thank You to Mrbil For This Useful Post:
  11. #6
    Jul 2020
    if converting from a rb30s settup a new accelerator cable will be needed also.
  12. The Following User Says Thank You to Mrbil For This Useful Post:
  13. #7
    Aug 2021
    Can you please contact me ASAP 0455435952
  14. #8
    Whats going on? You'll need someone who has done the conversion. I only started this thread to get as much info in in the one place, for those who need it.
  15. #9
    Quote Originally Posted by Gqpatrol2021 View Post
    Try starting a new thread and ask for help, that way.
  16. The Following User Says Thank You to mudnut For This Useful Post:
    mudski (17th August 2021)
  17. #10
    http://www.nissanpatrol.com.au/forum...-r31-loom-help
    For those having trouble getting the injectors working.
