Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 2010 GU Series 7 A/C Condensor fan (lack of).
    Expert clubbyr8's Avatar
    Penrith, NSW
    I know there are several posts on this subject, but I was wondering why some vehicles have them installed and others don't (I don't). What size fan is normally installed? It's been mentioned it's installed on the RHS (passenger side) of the condensor, why not over the whole thing? Anyone have pics of one installed in their car? Would the wiring be there since some cars of my model have them and others don't? I guess the fan would be set up as a pusher as there's no room to mount it behind the condensor. Any help appreciated....
    GROOVY GUVII
    Hunter
    they are not fitted to newer patrols
    GU8 Simpson Pack-Auto 2" lift, Dual Batts
    Hunter
    it is normal not to have one fitted
    Hunter
    The fan shroud in the engine bay has a cut out for the condenser fan on the passenger side to allow airflow
    If you a/c is working fine I would not worry about it
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The condenser fan mounts on the passenger side in front of the condenser. I installed a condenser fan out of a series 4 in mine. It bolted straight in.
    The relay is located in the relay box beside the battery. The switching side of the relay was already there. So the condenser fan is still ECU controlled. You just need to run a power supply to the relay and wire harness from the relay to the condenser fan.
    The A/C will be more efficient with the condenser fan fitted.
    I can post a photo of the condenser fan mounted if you need it.
  7. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    clubbyr8 (29th January 2016), schanmala (29th January 2016)
    Penrith, NSW
    Thanks mate, I'd appreciate a photo if you could provide one....
    GROOVY GUVII
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
  10. The Following User Says Thank You to Yendor For This Useful Post:
  11. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    This one shows the top mounting
  12. The Following User Says Thank You to Yendor For This Useful Post:
  13. #9
    Penrith, NSW
    Thanks Yendor, all I got to do now is find one...lol
    GROOVY GUVII
  14. #10
    Penrith, NSW
    Looking at the relay box, the only unpopulated relay base is top row, 2nd from the left and is labelled Shift Lock/Rad Fan, is this the relay position you're talking about? If it is, does it take a standard blue Nissan relay? Or am I looking in the wrong area?
    GROOVY GUVII
