28th January 2016, 09:35 PM
Weird hub noise
I've got a set of AVM manual hubs (the red high performance version) the drivers side is making a weird sort of rattle sound when in 2wd and unlocked. I presume they just need some grease but the weird thing is that I got rid of the auto locking hubs a year ago because the drivers side was making a weird noise. The noise goes away if the hub is locked. Could it be anything other than the hub?
Sent from my D2302 using Tapatalk
WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
28th January 2016 09:35 PM
29th January 2016, 12:27 PM
Most likly the hub.
If locked, and you hear a clicking sound can be hub or cv
29th January 2016, 02:16 PM
GQ TANK
Most likly the hub.
When the hub is locked in either 2WD or 4WD then no noise at all. I just thought it was a coincidence that I had the same problem with both the factory auto hubs and the after market manual hubs on the same side of the car.
29th January 2016, 02:21 PM
Check the wheel bearings or its a cv joint
The Following User Says Thank You to Sir Roofy For This Useful Post:
dom14 (2nd February 2016)
3rd February 2016, 08:11 PM
roofy
I wondered about that, but if it is in 2WD and the hub is unlocked, won't the CV be stationary and therefor not make any noise?
