27th January 2016, 01:14 PM
#11
threedogs
Those with a tank how have you dealt with the condensation,
just empty the tank every now and again into a seperate container.
Either with a spring loaded drain plug or a simple tapered one.
Might grab the tank [5 gal] out of the Troopy and fit it somewhere on the Patrol.
I have a hose that runs from under the tank with a tap and empty it out..
The Following User Says Thank You to Bloodyaussie For This Useful Post:
threedogs (27th January 2016)
27th January 2016 01:14 PM
27th January 2016, 04:16 PM
#12
http://www.ebay.com.au/itm/PIRANHA-A...IAAOSwhcJWMc8o
Heres a small tank to keep the pressure up to your lockers.
Being square it would fit just about anywhere.
This is about the cheapest tank I could find,
maybe its cheaper to buy a SCA 240v one and strip it down
http://www.ebay.com.au/itm/321240440...%3AMEBIDX%3AIT
28th January 2016, 12:09 AM
#13
Well fair point td..
Who said they have to be round??
28th January 2016, 02:38 AM
#14
What size tank would be worth while.
A while back I though out a cheapee compressor due to the pump failing, j sjould have kept the tank
28th January 2016, 08:41 AM
#15
GQ TANK
I would think 6-10L.. so 8 would be perfect lol..
A 90-130psi switch.. 150 psi relief valve..
Sorted..
28th January 2016, 09:28 AM
#16
All the Comp trucks Ive seen only had a 3ltr hotdog tank to run their lockers.
But if you want to run a rattle gun fit the biggest you can find, I had a 5 gallon
in my other 4x4, Really up to what space you have available, also if you are
hard mounting the compressor as well
28th January 2016, 12:15 PM
#17
I am he, fear me
biggqwesty
They are round so the air can't hide in the corners... maybe someone can also figure out why a boxing "ring" is square
The Following User Says Thank You to the evil twin For This Useful Post:
BigRAWesty (28th January 2016)
28th January 2016, 03:26 PM
#18
the evil twin
The Following User Says Thank You to BigRAWesty For This Useful Post:
the evil twin (28th January 2016)
28th January 2016, 04:32 PM
#19
I bought a cheap 240v compressor with tank from Bunnings for less than $50. I think the tank is 9L. The compressor was useless, so I threw it away, but the tank works fine, comes with 100psi switch and two pressure dials. Works for me....
The compressor is a Spear & Jackson Project Air, I kept the 100psi switch, the safety valve, the inlet and outlet pressure gauges, the pressure regulator and the Nitto connector, pretty cheap imho....
GROOVY GUVII
The Following 3 Users Say Thank You to clubbyr8 For This Useful Post:
BigRAWesty (28th January 2016), Skitzyrex (28th January 2016), threedogs (28th January 2016)
